GLE Class (W166) Produced 2015-2019
Can’t patch up
Old Oct 26, 2018 | 04:09 PM
softfree's Avatar
gle 350 2016
Can’t patch up
little nail.....
Dealer says can’t plug it on the side. Need to replace the whole tire around $300 any advice?
Old Oct 26, 2018 | 04:45 PM
ItalianJoe1's Avatar
2003 CL 600
Replace the tire. Can't repair runflats, can't repair any tire on the sidewall.
Old Oct 26, 2018 | 05:02 PM
softfree's Avatar
gle 350 2016
can you see my picture? Just want to make sure I don’t get rip off
Old Oct 26, 2018 | 06:50 PM
chassis's Avatar
2017 GLE350 4MATIC
I see the picture. Replace the tire.
Old Oct 26, 2018 | 08:36 PM
softfree's Avatar
gle 350 2016
Thx they say it’s ok replace only one cause low mileage on other tire.
Old Oct 27, 2018 | 12:05 AM
2003 CL 600
Yeah you are fine to replace tires single, but you can't repair the tire on the side like that.
Old Oct 27, 2018 | 09:04 AM
RA112623's Avatar
thank you steel belted radials
i did have a dealer do a "plug" on a tire in a similar area. short term though. it was a light car and the tire was coming off in a month or so. consider yourself lucky it's low mileage. good luck, ron
Old Oct 27, 2018 | 09:10 AM
hyperion667's Avatar
2012 CLS63
Yep, replace it. Also, look into different stores for tires......Discount Tire would have replaced that for free. Good luck.
Old Oct 27, 2018 | 11:32 AM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
Dumb question, but: Are you certain that the screw penetrates all the way through the tire?
Old Oct 27, 2018 | 11:46 AM
softfree's Avatar
gle 350 2016
It was leaking not sure went all way down
Old Oct 27, 2018 | 08:56 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
to me its not in the side wall of the tire. The side wall is the part of the tire between the rim and the tread. I would certainly get a second opinion and from a tire store vs the dealer. I think you can repair it.
Old Oct 28, 2018 | 09:45 AM
softfree's Avatar
gle 350 2016
on the invoice, sidewall puncture .........continental 255/80r19 cost 247 tire tax 2.5 fee 35=289.50 plus sale tax
Old Oct 28, 2018 | 10:23 AM
RA112623's Avatar
or so you would think. right on the edge of the belt, so that's that. if you only do local driving you may want to ask about a plug, but probably not worth the risk. good luck, ron
Old Oct 29, 2018 | 12:04 AM
2003 CL 600
No, once you get to within about an inch of the edge of the tread, that area flexes too much to be repaired safely. It will not hold up. Runflat tires are not supposed to be repaired anyway according to the tire manufacturer as they can't guarantee the runflat capabilities of a repaired tire anymore.
Yes, a plug may hold temporarily, but every one I've seen plugged on the side like that starts leaking again in a very short time. I've done it before to make it last a day or two until I get the replacement tire, but I would never suggest it to a customer.
Old Sep 4, 2021 | 11:56 AM
softfree's Avatar
gle 350 2016
Got Another tire with nail on. Can this patch or plug in ?
Old Sep 4, 2021 | 12:34 PM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
Doubtful a tire shop would repair. You could try to repair yourself with a plug kit... I would not... While generally not a fan of aftermarket tire road hazard warranties, the past few years I've had at least 6 tires replaced on various vehicles...All were covered under a tire road hazard warranty. There is alot of road construction going on in Central Florida where I live.
Old Sep 4, 2021 | 02:40 PM
2012 CLS63
Old Sep 4, 2021 | 06:25 PM
chassis's Avatar
2017 GLE350 4MATIC
If it was mine I would plug it. Your decision, however.
Old Sep 4, 2021 | 06:39 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
I had a nail in almost the same exact spot. It was repaired and I drove on it until the tires wore out… FYI.
Old Sep 5, 2021 | 12:21 AM
softfree's Avatar
gle 350 2016
Did they do it plug in or patch ?
Old Sep 5, 2021 | 04:16 AM
Chefcct's Avatar
They repaired it from the inside after removing the tire from the rim.
Old Sep 5, 2021 | 08:35 AM
gle43FL's Avatar
Veteran: Army
2024 GLE580, 2013 Jeep Wrangler, 2018 GLE43 AMG *Sold*
I would get it patched, not plugged
Old Sep 7, 2021 | 03:56 AM
amusa's Avatar
16 GLE400 4matic
Mine was almost the same location as the first pic. Lucky I had (1) used tire in the tire stash with the correct size at the shop. I did not care since I'm replacing all (4) tires soon.
