Camper towing with my GLE 350
Subscribe
Jan 26, 2023 | 09:57 AM
  #151
Quote: I think you missed "DO NOT exceed vehicle ratings" at the bottom.
Hitch can be installed on several different vehicles, so it can be much stronger, than vehicle it is mounted on.
All good, Max. stands for Maximum that ZeroAGL was asking about and the decal shown is just one source, like tire pressure on the fuel door decal. The V5, I'm told, is the designation that this is a Class 5 that exceeds the vehicle rating and give the maximum vehicle tow limits. Dealers have told me they considered it even cost-prohibitive to add on this hitch with all the systems such as blind spot monitoring and trailer stability control that come the the 550 trailer hitch option code.
Reply 0
Nov 16, 2023 | 10:06 AM
  #152
Towing with Andersen W/D Hitch
Long time guest reader, first time poster.
I know this is an old thread, but it’s been so helpful and informative that I had to post my appreciation of everyone’s input on towing with a GLE 350. Thank you all!
I had a 5x12 single axle that wasn’t very heavy and the GLE pulled it ok-ish. Lots of bounce & bucking and stopping was a chore.
I now just bought a 7x18 V-nose dual axle with electric brakes. Following the advice of you all, I hooked up the P3 Brake Controller and added an Andersen W/D hitch setup. I tell you what, that combination make pulling this new trailer SOOOOO much better than the old 5x12 I had. No bouncing/bucking and the adjustable brake gain makes it feel like there’s nothing back there when stopping.
Everyone was giving me crap for pulling a trailer like this with a Mercedes, until they rode with me and found it handles a trailer better than their trucks do. I just laughed at their reactions as they are on the mentality that truck are the only thing that can pull trailers…
Anyways, thanks everyone for the tips and information which created such a great setup and I look forward to many miles of towing!
Reply 0
Nov 16, 2023 | 11:29 AM
  #153
Great feedback and glad its working for you.
Can you share the trailer weight you are pulling and hitch weight?
Thanks!
Reply 0
Nov 16, 2023 | 08:47 PM
  #154
Thanks!
Yeah no problem. The trailer is around 4200lb loaded and has a tongue weight around 450lb.
Reply 0
Nov 17, 2023 | 04:27 PM
  #155
Do you really need WD bars on GLE?
I did tow a lot with older W163 and now with W166 and never needed them.
Also did you hook up brake controller? How did you find harness?
Reply 0
Nov 17, 2023 | 11:00 PM
  #156
Yeah, the tongue weight was over 600lb. So, with the limit of 600lb on the factory hitch, I just opted to use the WD hitch which doesn’t use traditional bars, it uses a chain setup that’s much better.
I found the brake controller adaptor for the P3 on Amazon and plugged it into the factory harness that’s tucked up under the knee panel on the drivers side. If you have the factory hitch installed, you’ll see a green plug tucked up there.
Reply 1
Nov 20, 2023 | 08:47 AM
  #157
Brake Controller Thread
Quote: ... Also did you hook up brake controller? How did you find harness?
https://mbworld.org/forums/gle-class...oller-fyi.html
Reply 0
Nov 21, 2023 | 09:51 AM
  #158
Huh, buying a trailer is actually my strong desire. But i imagine how many problem will i have with all of these stuff... You know what i have found useful for my rv? awning shade screen cause you know especially when we talk about camping in summer with sn shining bright, this thing is useful enough to boost your comfort at your rv while resting on the highest mark possible. I guess it is a good upgrade for my next summer
Reply 0
Explore
Nov 21, 2023 | 11:16 AM
  #159
Quote: https://mbworld.org/forums/gle-class...oller-fyi.html
I read that.
Unfrtunatelly most of the links in the thread don't work anymore.
I think buying pegs and wire at dealer and assembling the harness is still valid, but I'd rather buy something ready to use.
Reply 1
Nov 21, 2023 | 11:17 AM
  #160
Quote: Huh, buying a trailer is actually my strong desire. But i imagine how many problem will i have with all of these stuff...
What kind of trailer?
Trailers below 1500lb don't need brakes, what simplify lot of the issues.
Reply 0
Subscribe
Currently Active Users (1)
