GLE400 with Dinantronics Sport Piggy Back Tune
Does it actually "adjusts the tune" (adjusts the boost/performance up/down in a given mode, I find it unlikely but one never knows) or just simply an ability to switch between unit's modes on different phone/tablet devices?
FWIW when I had the Comand screen on engine performance, the time to hit the full 362 hp level on the screen came a lot quicker in Race mode than stock mode and kept going a bit... there is some noticable pull in the higher RPM range (above 3,000 or so)... the butt dyno feels a bit more power...
it is certainly not near as noticeable as some tunes I've run before... have a nice JB4 where I run 96 octane in my N55 BMW X1
I have installed dinantronics in my GLE400 and I love it so far. My observation till now:
- Throttle response is better.
- Gear shift up early. Used to see that my gear matching the car speed (while going 50-55 km/h I would be in the 5th gear. But since I have installed dinantronics I have seen my car in 6th gear while speed reach 53 km/h).
- Engine oil is normal. Maxed at 102 degree C while outside temp is 44 degree C).
All in all I am satisfied with this purchase. I got carried and bought K&N filters but still have not install them.
#32
After some initial challenges, the piggyback tune works well for what it is...I added a Pedal Box throttle tune and both work rather well in combination and also allow reverting back to stock with the App...
By all means it is not a 63 but a very lively ride non the less
#33
MBGLE400MEX (09-09-2024)
#35
Thank you man, so basically with the APK from them you can use any phone (newer) and modify the tunes. This is what I wanted to hear/see.
I just ordered mine directly from Dinan, will update after a week or so of using it.
Regards!
Regards!
#36
Dinan app last version of the APK (works with any version of Android)
Just in case anyone need the LAST updated APK file for the Dinan app, here it is...
D-SPORT_SDK15 (3).apk
