GLE Class (W166) Produced 2015-2019
Leak cam gasket ?
Old Jul 16, 2020 | 04:35 AM
MBGLE350's Avatar
GLE350
Leak cam gasket ?
Just bought my 2016 GLE350 couple month ago did an oil change notice some oil spot around the engine bay looks like gasket seal may need replacement uploaded some photo please zoom in, anyone had this issue cost of repair? Thanks
Old Jul 16, 2020 | 08:41 AM
chassis's Avatar
2017 GLE350 4MATIC
I have similar leakage on a 2017 3.5L V6 M276 DE35 with 45k miles. It’s a kindergarten level fail for Mercedes Benz.
The oil cap residue looks like it could be spilled oil from the oil change, the pictures are not very good quality.
The others are what the dealer and Mercedes call “vapors” and in their view are not leaks. Therefore in their view are not warranty repairs. There may be the usual variation in interpretation among dealers on this.
I don’t see cam cover re-gasketing reported on this site much. It could be that these leaks, which is what they are, do not sufficiently increase over time to cause concern.
Replacing gaskets looks tricky to me because there are three or four parts that come together (poor design Mercedes, you know better) at the front chain cover, cylinder head, cam cover and cam position solenoid cover plate. This means a lot of disassembly and care when resealing is needed.
I have experience with leaking poorly designed engines, namely the 4.2L inline six from Jaguar in the 1980s. A bad design cannot be made to be leak proof.
In the M276 DE35 there are too many parts coming together at a physically concentrated point, and the normal engine vibration causes the seals and gaskets to fail. No amount of resealing would fix something like that, it recurs again and again.
Old Aug 11, 2020 | 02:16 PM
audi10021075's Avatar
ML 350
Old May 27, 2021 | 08:19 AM
amusa's Avatar
16 GLE400 4matic
I know it's an old thread. My friend (Mercedes Master Tech) said it's very common leak on all the M276 motor. He said some coating that they use at the assembly manufacture plant. He told me to clean it and get the coating off and should fix it.
This thread will help on DIY
https://mbworld.org/forums/c-class-w...gine-guru.html
