Lowering Module OBD-2 Plug-and-play Airmatic
Thanks for clarifying.
J
J
Whatever height you set up your module too will be become the new default height at "Comfort". So when you go to "Sport+" mode, it'll drop even lower, I haven't measured it but my guess its the same amount of drop from factory settings. My settings on the module are "Low" and when switch to "Sport+" the stance gets real low where you sacrifice comfort, but looks slick as hell!!
THAT’S RIGHT - REASON BEING “OEM” THERE IS NO FRONT CAMBER OR CASTER AND NO REAR CAMBER !
FACTORY / OEM - There is only basic front and rear Toe “directional” adjustment.
NO ADJUSTMENT ESSENTIAL TO CHANGE TIRE CONTACT ANGLES toprevent excessive edge wear / spread load more evenly.
To cater for other then showroom height conditions. Day to day commuting....
Encountering high cambered roads with excess passenger side edge wear. Wheel squat through load carrying or lowering. Fitting wide profile tires or just having the ongoing ability to adjust for curb knock damage.
K-MAC FRONT (Camber & Caster) adjuster kit also same time replaces the ‘4’ Front highest wearing bushings.
(the rear ‘2’ suffer from premature failure and OEM are expensive to replace).
These K-MAC front (and rear) kits are supplied with bush extraction tools allowing fitment without need for arm removal.
See Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
