GLE Class (W166) Produced 2015-2019
2017 GLE 350 Brake Torque Specs?
Old Oct 18, 2021 | 10:49 AM
SamPamm's Avatar
gle-350
Hello! New member here. I did a search thru the forum but was unable to find what I was a looking for for this year and model car. Hope you can help.
Wife's 2017 GLE-350 needs new brakes, so I plan on replacing front/rear pads and rotors, sensors. I have all the tools, correct sockets and have done the rears before, but need some specific info for completeness and correctness:
1. Torque specs on the front and rear caliper bracket bolts,
2. Torque specs front and rear caliper bolts,
3. Torx size for the center of the 13 mm rear caliper bolt,
4. Service thickness limits for the front and rear rotors?
5. Any on-line or published service manuals?
6. Can someone explain the body type designations (W166 for example)?
When I'm done I'll post a "how-to" for others. Thanks for your help!
Old Oct 18, 2021 | 03:00 PM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
Get a copy of WIS and EPC from Ebay. Best source for service.
If you want exact torque specs and rotor thickness you need a VIN because different models with different options have different specs.
Old Oct 18, 2021 | 09:44 PM
chassis's Avatar
2017 GLE350 4MATIC
Read my GLE ownership report thread. The rear brake procedure is listed there.
Front brakes attached. Caliper bolts are specified for replacement (single time use).
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 19, 2021 | 10:26 PM
SamPamm's Avatar
gle-350
Chassis:
Thank you so much! I was pretty close in my estimates but now I know, though it appears the caliper bolts are not as tight as I thought. I also found your write ups and extra info on the brakes and rotors on you GLE owner's thread (for anyone searching, the brake info you seek starts at #113 with more info downthread at #147)). Nice write-ups on the various DIY projects. My wife's GLE is now out of warranty so I'll be changing the oil as well.
Also, you provided the WIS. I looked around ebay and the forum for the WIS/EPC, and some of it appears "shady". Is there a source you trust, perhaps your own?
Old Oct 20, 2021 | 06:50 AM
chassis's Avatar
2017 GLE350 4MATIC
Look for seller Gary Ive or similar.
Old Oct 21, 2021 | 11:48 AM
SamPamm's Avatar
gle-350
Got it, thanks!
