GLE Class (W166) Produced 2015-2019
GLS 450 vs GLE 43 amg engine
Old Jan 17, 2022 | 10:49 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Is the engine of the X166 450 the same as the GLE 43 AMG? Is the tune the only difference between the two or is there more into it?
Old Jan 18, 2022 | 07:24 AM
chassis's Avatar
2017 GLE350 4MATIC
The base 3.0 TT V6 is the same. There are likely detail differences including potentially tuning differences. The best way to know is to surf EPC and compare part numbers for the two engines.
At a minimum the GL/GLS and the ML/GLE will have tuning difference based on wheelbase and vehicle weight.
Old Jan 18, 2022 | 11:09 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
AMG tune in the past was rebuilding whole engine. No clue if that apply here, but bigger pistons, bigger valves, bigger exhaust.
Old Jan 18, 2022 | 12:34 PM
chassis's Avatar
2017 GLE350 4MATIC
@shotgun_banjo When you look up Wikipedia or the MB owners manuals for these two cars, what are the torque and HP specs? How much difference is listed in these values?
Old Jan 19, 2022 | 12:34 AM
Difference is very small hence I am curious if only a tune makes it different.
GLS 450
Engine Type: 3.0L V6 biturbo
Engine Material: Aluminum-Alloy
Valvetrain / Arrangement: DOHC, 4-valves per cylinder
Displacement (cc): 2,996
Bore (in / mm): 3.46 / 88.0
Stroke (in / mm): 3.23 / 82.1
Compression Ratio: 10.5 : 1
Horsepower @ rpm: 362 @ 5,250 - 6,000
Torque @ rpm: 369 @ 1,800 –4,500
Redline (rpm): 6,500
GLE 43 AMG engine:
Engine Type: AMG-enhanced 3.0L V6 biturbo
Horsepower @ rpm: 385 @ 6,100
Torque @ rpm: 384 @ 2,500 – 5,000
Old Jan 19, 2022 | 08:42 PM
chassis's Avatar
2017 GLE350 4MATIC
The spec difference listed above is well within the range of tuning differences.
