How to swap cig lighter fuse to keep power on '18 GLE 350
Hi all:
I installed a dash cam in my truck and needed to plug into the cigarette lighter. but when i turn off the truck the cig lighter turns off and my dash cam has no power. I pulled the diagram from my fuse box in the truck and it says the fuse is in the back seat floor, fuse F-148. Question is where do i move fuse F-148 to what section of the fuse box where the power is always on. Please help. Thanks
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
You are better off putting in a separate circuit and outlet to bypass systems if you truly want an always on circuit. Many circuits enter sleep mode after a while and may not accomplish what you want.
FWIW I added a separate outlet for accessories in the cubby area under the main dash panel.
Wire it directly to an always hot source and add a fuse.
