GLE Class (W166) Produced 2015-2019
Weird sound when braking
Old May 11, 2022 | 11:09 AM
ratty's Avatar
GLE43AMG, CLA 250
Hi all
I have a 2018 GLE 43 (AMG) that had its brakes replaced 5-6 weeks ago. Granted, I don’t drive this car much usually. Use it to make quick short local errands etc. Everything has been fine except I noticed this weird sound it makes usually when braking. Although I don’t notice it when stopping in traffic, stop sign, etc. (that i recall). Whenever I pull the car into the driveway that’s at a 20 degrees or so downslope, it makes this noise as I tap the brakes to inch into our crammed city townhome driveway. Occasionally, I’ve also noticed it when tapping the brakes while parking but not to the degree of the sound in the clip. This was the loudest. Should I be worried or is this normal sounds due to the angle?
Here is the link with sound:
https://imgur.com/a/Vt9rfMh
Thanks in advance!!
Old May 12, 2022 | 05:31 AM
amusa's Avatar
16 GLE400 4matic
Sounds like the ABS pump low brake fluid, maybe? Check your brake fluid to see if it's low. I let other chime in.
