Passenger front window noise
I am guessing some lubricant is washed away and the glass is rubbing against the weather stripping?
Anyone else have seen this?
If yes how did you fix it?
Thanks, I bought this.
How do I apply? Roll down the window and apply on all rubber gasket around window?
What about trim inside the door frame?
I just rolled it on and then later I just cleaned it off the body paint.
I use it everywhere that is exposed like the rear hatch door and moonroof/sunroof, etc.
Where?
Between the two black strips where window goes down?
What about window frame sides?
I did roll on above places and I think it made a difference, I had to clean up window itself from residue.
Where?
Yes
You can. I did not do it on mine just the bottom strip
