GLE Class (W166) Produced 2015-2019
Thoughts on a never serviced GLE 43
Old Feb 9, 2024 | 09:49 AM
isosunrise91's Avatar
Lexus IS
I have been searching for a GLE 43 SUV (not coupe) for sometime. Came across one in my area with 122k. Car fax shows not a single service record. Looks like one owner. Of course the 43 is simple when compared to the 63 but still worrisome that not a single service record exists. Anyone have experience buying a used one with high miles?
Old Feb 9, 2024 | 11:36 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Its been only last few years, when Carfax will show service done at licenses shops.
For decades people were buying cars without Carfax and when that did lead to some cheating, it did work.
Whenever I buy used vehicle, I start with blow-by test.
Than take it for a spin and compare 0-60 time to what original spec are giving.
Even if the seller DIY the service, he suppose to have it recorded this way, or the other.
Finaly on modern cars, a scanner will give you record of FSS resetting.
Old Feb 9, 2024 | 12:09 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Just because a service record doesn't exist doesn't mean that service wasn't performed, either at an independent shop or the seller is a mechanic himself and does his own work. Carfax and dealerships isn't a guarantee that quality work was or was not performed.
Old Feb 9, 2024 | 01:00 PM
mercedesmax's Avatar
2015 CLS 550 2015 ML 400 Previous 2020 GLB 250 2019 A 220 2005 ML 350 1989 300 E 2001 SL 500
Ask the seller for service records. Pass if they don't have any or the car was serviced at Jiffy Lube.
Old Feb 10, 2024 | 03:39 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
A car with 122k on the motor without a single service history means = walk away. I rarely see an MB without teething problems in the first 4 years which will be fix by a dealer. Depending on the year there should be at least 1 recall on the vehicle which should be checked and fixed. If that is not done ask MB if they will still do it. If not, walk away.
