GLE Class (W166) Produced 2015-2019
ERROR Message U040100 how to clear
Old Apr 8, 2024 | 08:17 AM
Thangvan's Avatar
Gle 350d
Hello, my GLE was left in my garage for an extended period and I had to replace both aux and main batteries. Then these messages came up when I scanned
Left fron reversible emergency tensioning retractor U040100 - Implausible data was received from control unit 'combustible engine'
Right fron reversible emergency tensioning retractor U040100 - Implausible data was received from control unit 'combustible engine'
How do I resolve this?
Old Aug 14, 2024 | 12:12 PM
dwork's Avatar
ml350
hi, did you ever get your u040100 fixed i having the same issue
Old Aug 16, 2024 | 04:52 AM
amusa's Avatar
16 GLE400 4matic
Possible Causes:
  • Issues with Power Source (Alternator Charging or Battery)
  • Check ECM/PCM/ECU fuses
  • Wiring Harness Open or Short (Check Connections)
  • ECM/PCM Module has bad ground
  • Faulty ECM/PCM
What vehicles is this for?
I had this code back in 2019 and the dealer replace the main battery due to low voltage. - I see you replace the main and Aux battery.
Old Aug 16, 2024 | 04:15 PM
dwork's Avatar
ml350
more info this code is on 2015 ml350
Old Aug 26, 2024 | 05:42 PM
Mitche11's Avatar
2015 GL350
same here. Anyone find resolution?
