Help with jacking from the front
If you have to pump up your floor jack so much before it finally reaches the jacking point maybe get a truck/suv jack. I have one from when I owned a Grand Cherokee. It has an adapter.
I helped a neighbor do his ball joints in his Wrangler last summer and we ended up putting some blocks of wood, like 4x6's lined up and put my big 3 ton floor jack on it then raised the front end. But to note at no time were we working under the car.
I have 2 floor jacks, 4 jack stands and 4 wooden ramps. The ramps are low enough I can fit them under the sides of the car and drive all 4 wheels up. If I need the front higher ill jack from the front middle jacking point then put the jack stands on the side jacking points. But I have yet to do a job where i need to be under the car WITH the wheels off. I plan on doing my transmission pan and fluid and when I do im driving it up the ramps, jack it up from the middle jacking point in the front then raise it enough to fit more planks under the wheels. For the rear ill use my two floor jacks and jack it up from the side jacking points then put more wood planks under the wheels then lower it.
I use scrap pieces of that white composite trim from Lowes, its made of a plastic it seems, it soft so it forms to the jack but doesnt split. Ill put that on my floor jack to make a cushion.
As far as the trim, do you mean this:
https://www.lowes.com/pd/Metrie-PVC-...-Ft/5013353105
