GLE Class (W166) Produced 2015-2019
Torque Converter Service?
Old May 5, 2025 | 06:34 AM
Sammy1836's Avatar
GLE 400
Hey guys, so on today’s episode lol….
i basically did my transmission service about 35k ago, and I never did the torque converter fluid flush / change.
I can’t really find much info on if this is should be even done or how to even do it? Any info would be appreciated as always 😁🙏🏻
2019 GLE400 (9G Transmission). Also are there different variants of the 9G? Or all the 9G take the same transmission fluid?
Old May 5, 2025 | 07:04 AM
chassis's Avatar
2017 GLE350 4MATIC
TC drain should be done when trans oil is replaced, if a TC drain screw is present. It is not clear if all transmissions were built with drain screws.
Old May 6, 2025 | 06:02 AM
Sammy1836's Avatar
GLE 400
Is there anyway to find out how much transmission fluid is needed for the TC flush?
Old May 6, 2025 | 07:14 AM
chassis's Avatar
2017 GLE350 4MATIC
Use the search feature. WIS is posted dozens of times and dozens of site members have documented their projects for this.
Old May 6, 2025 | 10:38 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
If you got it done on a dealer ask if they did the torque converter drain. Majority of the time they will say "NOT NEEDED" then tell nicely you know there is a bolt for it and check to see if your car has it. If it has it they are obligated to do it properly if they are a mercedes-benz dealer as they are charging you for something they have not done and they can get in trouble with that. If your car has the bolt and they did not do it, do not go back there again and look for a specialist who does MB and get it done right.
Old May 8, 2025 | 04:41 PM
W205C43PFL's Avatar
Yes get it drained
