GLE Class (W166) Produced 2015-2019
Would you buy an extended warranty from CarMax on a 2019 GLE400 ??
Old Jun 23, 2025 | 06:00 PM
karma12345's Avatar
Car only has 39k miles and I don’t think I’ve ever seen a cleaner engine bay on a used car.
not from. A salt using state either based on the CARFAX 0 accidents, / owners.
they want like 3-4k depending on the warranty term. I’ve heard it’s not a bad warranty but also heard this is a fairly bulletproof platform and engine.
thoughts ?
Old Jun 24, 2025 | 04:48 AM
amusa's Avatar
16 GLE400 4matic
Personally for me I don't purchase the extended warranty.
Be careful with car max if you decided to purchase it I highly recommend having Mercedes to do a complete inspection on it.
Old Feb 12, 2026 | 12:28 PM
imtheking's Avatar
Former R230, W220 and W221 owner
thoughts ?
They have a 10 day window to return the car. Buy it and have a reputable shop inspect it, not the dealer, but a local shop that specializes in Mercedes.
If there are major issues, return the car. If not, buy the car and the extended warranty. I've heard carmax is good with honoring their warranty. I considered buying a car from carmax only because of the warranty. One repair on this car and it has pretty much paid for itself
Get a 3 year or 4 year warranty. At least have coverage during your financing term.
Old Feb 27, 2026 | 04:43 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Biggest things overlooked on the car are typically:
Lack of maintenance of:
  • Transfer Case Fluid Exchange
  • Front and Rear Differential Fluid Exchange
Other well documented issues:
  • Front Timing Covers
  • Tensioners Failing (Rattle on Startup)
  • Turbo Intercooler Leaking Coolant
  • Transfer Case Failure (Just change your fluid)
  • Camshaft Magnets Leaking Oil into the Harness
  • Camshaft Position Sensor Leaking Oil Harness
  • Corrosion on the Transmission Pan if you're on the East Coast
Does the Carfax cover Blind Spot Sensors or Technology + related items?
Will they be using Genuine Mercedes parts?
What shop(s) are you allowed to bring the car?
Proof of Oil Change Intervals? or is DIY allowed
These are the questions that come to my head
Hope that helps.
Old Feb 27, 2026 | 09:23 PM
Chefcct's Avatar
2016 GLE 350 4-Matic
I would like to add my thoughts on extended warranty coverage..I purchased a Carchex warranty on my 2016 gle 350 when the original Mercedes extended warranty ran out. Here are a few things I learned along the way.
1. I currently pay $149 a month and as long as ii keep the payments up, the car will be covered forever. In fact, I asked this question to them directly and they said yes there is no mileage limitation.
2. In their contract it states that they can use pretty much any brand of parts they want to repair the car. If you want to use genuine Mercedes parts, then I have to cover the difference in price.
3. I had to make sure that my local non dealer Mercedes mechanic who has been working on the car since day one would accept the warranty terms and coverage because they have to jump through some hoops to do repair work on my car.
So the bottom line is I would do it again.
I have had some repairs and they have been covered minus the $100 deductible fee per repair.
My car is currently at 125,000 miles. So because I can still get coverage and as long as i want, I think it’s worth it. Of course, you need to remember that I started the coverage at just under 100,000 miles when my original Mercedes extended warranty expired.
I hope this helps you with your decision.
Old Mar 1, 2026 | 01:45 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
so... about $1800/year for warranty coverage?
That way more than covers maintenance and repairs even on a Mercedes, exceedingly so if you DIY, using OEM or better parts.
IMHO, YMMV, IME, ETC
Old Mar 1, 2026 | 02:29 PM
Chefcct's Avatar
rapidoxidation,
A couple of things to keep in mind.
First of all I do not DIY anymore. I used to, but I gave that up years ago. I have an excellent local Mercedes master mechanic who does work for about half of what the dealer would charge.
For example, I had a coil pack go bad and cost me $100 total for the deductible.
Another example is broken coil Springs, again this cost me $100 total.
Lastly, the front panel on the air-conditioning went bad and again that cost me about $100 total.
So everybody has to decide is it worth it for them. I also am heavily weighting the fact that the car now has 125,000 miles on it. Which means every passing year more and more things will be going wrong with it that will be covered by the extended warranty. It gives me peace of mind.
Take care and have a great rest of your day.
