GLE Class (W166) Produced 2015-2019
GLE400 2019 will not start
Old Jan 16, 2026 | 10:28 AM
stingray_7219's Avatar
Changed main battery. Aux battery tested good. Changed starter relay 30 amp square fuse under the hood. Made sure starter is still good, jumped starter, still rolls over. Went to start engine only hear one click. What am i missing?
Old Jan 18, 2026 | 08:06 PM
chassis's Avatar
2017 GLE350 4MATIC
What codes do you have?
Old Jan 19, 2026 | 07:35 PM
Gazam's Avatar
Check the ground connections, especially the main engine ground strap. Clean and tighten all battery terminals and grounds. Faulty ground is common after battery work.
Old Jan 20, 2026 | 09:39 AM
amusa's Avatar
16 GLE400 4matic
Did you pull the cover out and stick the key-fob in and turn it manual, to see if the vehicle engine start?
