GLE Class (W166) Produced 2015-2019
Rear pads gone after 1 month since replacement
Old Mar 1, 2026 | 08:10 PM
Uranium238's Avatar
1987 Porsche 928 S4, 2009 Mercedes E350, 2011 Mercedes GL450, 2003 Mercedes ML350
I took my car to get the rear brake pads changed (2017 GLE350) about a month ago with new rotors.
The rears are gone already with less than 1,000 miles on them! There is a noticeable burning smell frkm the backs. I suspected the car was not put in service mode to retract the parking brake. The shop confirmed this was done. But why would this happen then?
Old Mar 1, 2026 | 09:52 PM
chassis's Avatar
2017 GLE350 4MATIC
Something is not right. Take it back to the shop and tell them to fix it at no charge to you.
Old Mar 2, 2026 | 08:16 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Not being in the mode the retract the pads just makes it a SERIOUS pain in the *** to get the new pads in. Now, say they really screwed the pooch and forced them had the caliper out and a piston fell out...then that freaking thing will kinda clamp down on the pad, not be properly adjusted - KILL your MPG as it was dragging going down the road and eating your brake pads in about 1000mi.
Old Mar 2, 2026 | 08:51 AM
Kein Ersatz's Avatar
'17 AMG GLE 43
More likely that the caliper is stuck, agreed service related issue, take it back and have the make it right regardless of the root cause.
Old Mar 2, 2026 | 08:54 AM
Mikes62's Avatar
If the pads were stuck against the rotor, wouldn’t you smell the brakes overheating and see the rotor color has changed from the heat?
Old Mar 2, 2026 | 09:27 AM
Uranium238's Avatar
Rotor has definitely changed color. I see the pads are gone on both sides in the rear, not one side. It would be unusual for both sides to suddenly have stuck calipers. I recall FCP Euro's youtube video mentioning the pads are directional on these. If installed incorrectly, overheating the discs can occur. They do smell after driving.
Old Mar 2, 2026 | 09:29 AM
Assuming someone put them on backwards/wrong...I would then go CRAZY. New pads, new rotors, new seals (anything rubber in the region) new bearings at a minimum - if not a new hub due to heat soak.
Old Mar 2, 2026 | 09:48 AM
Mikes62's Avatar
If sounds like whoever changed your rear brakes did something wrong.
Old Mar 2, 2026 | 09:59 AM
streborx's Avatar
Top Answer: 1
G550
Have you been refueling 3 times a week? Maybe the shop got confused and just swapped brake pads side to side.
Old Mar 2, 2026 | 10:19 AM
Uranium238's Avatar
Shop will refund parts and half of labor charged (install). Absolutely no confidence in these guys. Doesn't sound like they want the car back (said they have no time this week to take it apart again.)
I'm going to examine this myself, take pictures and send them the bill if I see further damage. It's a slide caliper, nothing complex about it. I bet the float pins were never even removed and greased and the caliper slides are binding with the pad to prevent movement on both sides due to pad installation gone wrong.
I don't think it's possible both rear calipers would fail at the same time. I can also put the parking brake into the retract position for service. The noise can be hearbefor the retraction.
Old Mar 2, 2026 | 11:29 AM
Uranium238's Avatar
Wheel off. Insane amount of wear. Inside pad looks the same. Both sides have equal amounts of premature wear.
Old Mar 2, 2026 | 11:30 AM
Uranium238's Avatar
Driver side rear. As mentioned same amount of abnormal wear.
Old Mar 2, 2026 | 12:32 PM
I do not think they ever changed the pads.....
Old Mar 2, 2026 | 12:45 PM
Uranium238's Avatar
They definitely are the new ones. The backing plates look brand new still compared to the older pads which had surface corrosion.
Old Mar 2, 2026 | 02:05 PM
I dunno man - for me, that is about a 1hr job...not sure why a shop would not just fix it, create good will and move forward.
Old Mar 2, 2026 | 02:08 PM
Uranium238's Avatar
Because I have a feeling that they installed those pads backwards which is what caused this, and they don't want to own up to it.
Old Mar 2, 2026 | 02:24 PM
I cant say that I agree that putting in a pad "backwards" would cause this. I changed rears just last week (EBC pads were indicated on them what went where). I seriously looked hard at them and could not figure how it would even be possible to put them in backwards, well, unless I put the backing in and the friction media to the outside of the caliper. In the image (of my pads I took out last Thursday) - granted NOT THE SAME PADS. The package of rears has four identical pads in it. The "direction" is right to left - unless you put in the pad backwards (yours, in the image are not backwards)....it is not the pad. In the image - the R and L indicate are visible from the outside of the caliper (meaning all letters are outward of the rotor). Backwards just makes no sense....
Note: that really is my set of pads...not some internet image.
Old Mar 2, 2026 | 02:48 PM
Uranium238's Avatar
This thread is what led me to believe the inner and outer were swapped on both sides. See post #3
https://mbworld.org/forums/m-class-w...-2012-btc.html
Old Mar 2, 2026 | 03:52 PM
Odd, I maybe nuts. On the pads in my image - you can put the wear sensor on any of the pads. This is not the same as the wear sensor in the GLS or regular E or C. The pads that have a hole in them for the sensor to go into the media - if I am not mistaken, the sensor (not the OE one) would even reach the hole if it is on the outboards side of the caliper....I may be 100% wrong. That said, having replaced quote a few of them - other than the hole, I have never seen a difference in the pads themselves (and a few times all four pads had that hole).
In this image (from FCP) we see your correct brake pads. The shape, thickness and what not seem to be identical. The only variation would be what two pads have the hole in the media to fit the sensor...it would make sense that if the wrong pad was in the wrong place the sensor (wire) would break. The pads rubbing and what not? I cant comprehend the physics behind why that would be. The caliper is a dumb hydraulic device. The sensor does nothing more than complete a dumb circuit.
Old Mar 2, 2026 | 05:58 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Once you have your car back in your possession after the brakes get replaced (again), jack up the rear axle and spin the tires. Are the brakes still binding? Is it possible that your brake fluid is so shot that the proportioning valve is sticking on the rear brake circuit and can't release pressure as it should?
If your caliper pins were not sliding I'd expect to see only the inboard (piston side) brake pad to be bad, and as has been mentioned it isn't too likely that BOTH calipers are suffering the same condition. Look upstream. Why aren't the calipers releasing?
Old Mar 2, 2026 | 08:14 PM
Originally Posted by Triol
Did the shop know to put the parking brake in service mode? And then take them out of service mode. Since the parking brake uses the same pads that are used for the service brakes, the service mode releases the calipers so the pads can easily be replaced.
I am 99.9999% sure the second you put the car in D the service mode is off and the calipers wind back in...I was thinking about this over dinner (had to keep my brain off of office politics).
I bet about anythign this rumor of backwards pads stared with a shop that created the same issue...told the customer that "we had the pads in backwards" as that is easier than "we did not know what we were doing, did not know how to change the brakes or even the fact that the car has a service mode for the brakes"....and thus, an internet rumor begins.
Old Mar 2, 2026 | 10:59 PM
Uranium238's Avatar
CONFIRMED. Pads are on the wrong sides. I even see the damned sensor plugged in on the outer after washing the rear brake dust off!
Old Mar 3, 2026 | 01:33 PM
2013 ML350 Bluetec
I understand not everyone on the forum has this luxury but
THIS
Right here
Is why I work on my own car.
Old Mar 3, 2026 | 01:35 PM
Uranium238's Avatar
Yes and that is why I am replacing the rears myself and giving these idiots a 1 star on yelp.
There are explicit instructions all over the internet on how to identify inner and outer pads for these braking systems.
Old Mar 3, 2026 | 01:54 PM
streborx's Avatar
Top Answer: 1
G550
THIS
Right here
A luxury car does not make DIY a luxury (lol) -- but it does give you peace of mind !
