GLE Class (W166) Produced 2015-2019
Old diesel fuel
Old Mar 2, 2026 | 10:08 AM
RobertGLK's Avatar
GLK350
Old diesel fuel
I have a 2012 ML350 blutec that hasn’t run for four years. I need to find a way to drain the tank. Anyone have a way without removing he tank?
Old Mar 4, 2026 | 08:39 PM
Gazam's Avatar
Simplest way is to use the fuel pump itself. Jump the fuel pump relay in the fuse box with a fused jumper wire, disconnect the main fuel line under the hood, stick it in a jerry can, and let the pump do the work. Just make sure you've got a good battery or a jump pack on it.
Old Mar 4, 2026 | 08:57 PM
RobertGLK's Avatar
GLK350
Originally Posted by Gazam;[url=tel:9269334
9269334[/url]]Simplest way is to use the fuel pump itself. Jump the fuel pump relay in the fuse box with a fused jumper wire, disconnect the main fuel line under the hood, stick it in a jerry can, and let the pump do the work. Just make sure you've got a good battery or a jump pack on it.
that’s what I ended up doing. However after getting 10 gallons out and having a 1/4 tank still full it started blowing air/foam and the pump sounds quiet now. Could I have burned up the pump?
Old Mar 6, 2026 | 09:09 PM
Gazam's Avatar
Sounds like you starved it. Pump probably got hot and might be damaged. Running it on air like that kills them. Could be on its way out.
