GLE43 Coupe (C292) 2016 - Present (Includes GLE450 Coupe)
Airmatic Calibration HELP!!
Old Feb 9, 2026 | 11:51 PM
Marco R's Avatar
C32 AMG, GLK 350, A250 W177, GLE43 AMG
Hi everyone, I need some help from GLE43 AMG owners.I need to replace the suspension valve block and then calibrate the ride height using Xentry.Before starting the calibration, the car must be set to the correct “Comfort” height.Could you please measure the distance from the wheel hub center to the fender, using a metric tape, and share the measurement in centimeters? “As a reference, my vehicle has approximately 44 centimeters measured between the wheel arch (fender) and the center of the wheel when the suspension is at normal level.” (22"wheels)Secondly, do you know how to calibrate without using Romess, but only Xentry ? Any tips?
thanks in advance.
Old Mar 9, 2026 | 05:59 PM
How to benz's Avatar
GLK 220cdi 4matic 2013
hi
you must use an inclinometer like romess , it is nearly impossible to do it otherwise .
i am using a verry popular and not so expensive tool called ASAT it is much cheaper than romess .
