Got him lowered today...pic
http://adjustableairride.com/
Looks amazing in all black as well.
i never aligned the ML but I’m gonna do the GLE next week just cause I hate the factory setup being so aggressive it darts all over..
Lowering causes other issues that some can be addressed and others not...per the dealer as the vehicle uses information from the links to determine the chassis height the headlight alignment can be off after lowering...so this adjustment must be made for proper headlight performance...also the alignment device used at service uses a baseline height to calibrate the car and since this has been changed (after lowering) the standard alignment can no longer be performed....so the tech must "ad lib"
Regardless the resulting adjustment SO FAR seems acceptable as far as ride and control is concerned...time will tell if there is any detrimental tire wire and another note...I currently running on 21" winter Pirelli stock size big 295 rubber...the ride barely tolerable at 40 psi on these winter roads and will certainly be changed to either 19 or 20 inch wheels next year (vehicle came with this rubber,,,not my choice)
So lowering provides a more planted firmer (less suspension travel) feeling and possible performance and imprroved curb appeal (imo) but comes at a cost...nice part is it's easily reversible in 20 minutes to swap out links and a chassis/headlight re-alignment from service
Re "no rear adjustment left". We saw the need and manufacture rear adjustment kit that doubles the existing adjustment range of both Camber and Toe.
(replacing the 4 rear highest wearing suspension bushings at the same time).
Is precise single wrench adjustable, accurately under load, direct on alignment rack. Comes with bush extraction tool P/N 504026 K $480
For the front suspension there is no OEM Camber or Caster - only Toe directional adjustment.
Similar front kit manufactured also replaces the 4 (expensive OEM) highest wearing bushings. Provision of front Camber and Caster allowing to adjust tire contact angles. Catering for conditions encountered in day to day commuting - high cambered roads, fitting wide profile tires, wheels, altered height through load carrying or lowering. With ongoing adjustment capability for curb knock damage.
This front kit also comes with bush extraction tool P/N 504016 M $595
Delivery worldwide $30 one kit $50 Front & Rear
PayPal, Visa or M/Card
$100 vs. $500. I've been considering both. I've used links on all my vehicles and while adjusting them to get the perfect height and level at each corner can sometimes be tedious, I'm feeling a little time in the garage would be worth the $400 savings. Also for me once I lower a vehicle I've never had a need to return it to stock until I'm selling or trading it in. So the "easily return to stock ride height" isn't a value added feature.
One thing to note is on my ML I did have a corrosion issue after a full winter (even with the rubber boots) and broke a ball off the factory plastic arm. So make sure you use a long lasting grease if you are going to be seeing salted roads.
- Factory (Factory level of your car when our module plugged in for the first time);
- Low (Factory minus 32 mm):
- Custom (by default same as Low, but can be changed by user, min -70mm from factory, max +40mm from factory).
Any time you can return back to factory height after plug in the module only!
The lowering module rep told me that on this SUV you can only go 40mm safely so I'm trying to gauge the drop.
Thansk!
