Links or OBD Lowering?
Old Jun 28, 2020 | 11:40 PM
JAYCL600's Avatar
new balance
Which one is the go to for lowering this platform!
Old Jun 29, 2020 | 04:54 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
OBD. Lowering links will cause the car to be too low when driving at interstate speeds.
Old Jul 1, 2020 | 09:38 PM
Anotherone's Avatar
W463 G550, C292 GLE63s
Amazon/eBay module.
Old Jul 21, 2020 | 09:39 AM
Dmitry Gebber's Avatar
Mercedes-Benz
https://mbworld.org/forums/gle43-cou...ng-thread.html
Old Jul 21, 2020 | 08:49 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Not true...performs just fine
Old Sep 5, 2020 | 10:12 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Not true. OBD is easier though
Old Sep 7, 2020 | 12:48 PM
RaceTank's Avatar
GLE63s C63s S560
OBD module
Old Sep 8, 2020 | 11:03 AM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
If you lower you will need camber adjustable upper front control arms..
Old Oct 29, 2020 | 09:34 AM
Kebowers47's Avatar
001 s600, 94 sl600
IMHO The 'best ride height' is a well-researched by Benz compromise to best satisfy the many parameters that influence the handling and performance of the MBZ autos. A deliberate modification of these normal ride heights IS a 'personal experiment' searching for a better solution. One can very easily adjust a few things and 'improve' a single steering related characteristic, such as 'turn-in' feel by increasing the caster angle-- which will 'adversely affect' the 'on-center stability.' One can 'improve' the front wheels' ultimate cornering grip and 'feedback feel' by adjusting the Camber setting to provide a 'top-of-the-wheel' tip-in, but that increases the inside edge wear and rolling resistance of the tires. etc.,etc., etc.
The rear wheels must also be readjusted to perform 'better' with the different front wheel adjustments. If the auto is equipped with either Active Body Control or the pneumatic air suspension system the 'ride height' can be adjusted up or down by changing the height 'set-point' in the electronic control system. The modification of installing 'lowering links' has the same physical changes as re-setting the 'normal ride height.' Both modifications change not only the static position and suspension component loads but also the forces normally generated by the 'normal settings', to some greater than and some less than-the factory settings. Suspension 'compliance' will be 'adversely impacted', which may result in undesirable behavior under some conditions.
Because MOST Owners drive the auto on a wide variety of surfaces and many different weather conditions, there is no one 'best solution' for suspension settings and resulting handling characteristics. The engineering team for suspension design has to choose a compromise for each 'setting' to deliver the 'best overall' suspension performance for 'normal' driving conditions.
One can not and should not expect the overall suspension performance of their Owner Modified Suspension to be the same as it was before modification.
Old Oct 29, 2020 | 01:23 PM
Twilighthan's Avatar
GLE 63S
OBD. That way you can go UP as well or configure to the exact specification you need.
I used mine for the first time today. Can't wait to go off road with these new wheels, tires, and suspension level.
Old Oct 31, 2020 | 09:56 AM
CTE55AMG's Avatar
1991 300CE
I traded my GLE43 and have the Belarus / Amazon lowering module that you plug into OBD port. Simple and easy to install/uninstall. PM if anyone is interested.
Old Oct 31, 2020 | 06:41 PM
RaceTank's Avatar
GLE63s C63s S560
it gets locked to your vin. You cannot re-use it on a different car
Old Nov 5, 2020 | 02:49 PM
RaceTank's Avatar
GLE63s C63s S560
so if you had the code, wouldn't that mean you could switch between cars at any time?
What is the code?
Old Nov 8, 2020 | 09:31 AM
carlosamg50's Avatar
AMG GLS63
Hi all
Im wanting to drop the ride height on my GLS a further 15mm to close the wheel arch gap thats still a bit much even in S+, can an indy with Xentry do this no problem?
My dealer wouldn't do it so Ive not asked, a local indy who does a fair bit of work on Merc models has Xentry and it happy to have a look (he’s only ever set factory ride height rather than lower), but he said if he cant do it he’ll still have to charge a fee for the online service hook up for using the system to access my car (or something).
Can Xentry let the user enter manual values for ride height or do i need a specific lowering module? Im also weighing up links too.
Carl
Old Nov 8, 2020 | 08:23 PM
RaceTank's Avatar
GLE63s C63s S560
get the lowering module. It is the easiest option
Old Nov 8, 2020 | 09:27 PM
CTE55AMG's Avatar
1991 300CE
I used the module on 2 different cars, no problem, no code needed.
Old Nov 8, 2020 | 09:33 PM
RaceTank's Avatar
GLE63s C63s S560
which module?
Old Jul 14, 2021 | 06:45 PM
feso's Avatar
2016 GLC43 AMG
lowering module
Hi.
Did you sell the lowering module or is it still for sale?
Old Jul 14, 2021 | 07:00 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by feso
Hi.
So that everyone who reads this understands, all OBD lowering modules (regardless what the source is - "Amazon", "eBay", or Renntech) are VIN coded. They will not sell you the module without buyer providing them with the VIN first. Once module is VIN coded, the module CAN NOT (not withstanding what was said above) be used with any other car. The reason is obvious: the module makers/creators do not want module to be reused because it will greatly effect their sales (hope everyone can understand it).
Old Oct 4, 2021 | 12:27 AM
Jaimillocruz01's Avatar
2016 Mercedes GLE 63 W166
I already use my module in 3 Different vehicles
My module is probably open, ive already used it with 3 Different Mercedes
Old Aug 1, 2024 | 03:27 PM
Mike0123's Avatar
2018 gle43
Stiff ride
I have the lowering module and tried various settings and they all resulted in the ride being too harsch. When you hit a bump or dip, the amg damper system even in comfort setting hurts my back. Do you guys have any suggestions (i.e. change shocks). Thanks
