Common maintenance
Old May 30, 2022 | 08:28 PM
Vyper340vb's Avatar
AMG GLE63S, X5M Comp, CTT, ZO6, Raptor
Originally Posted by AnotherSL
My 2021 GLE63S was delivered from the dealer as a CPO with 5,100 miles and the oil almost 1 qt too high! Their tech had changed it as part of the certification process. I found out when the warning dialog box came up just a mile after starting out on my first drive. The manual(s) do not state how much oil to put in after a filter replacement & drain.
I would suggest adding 8.5 qts then check the level after running the engine a couple minutes.
common mistake for unfamiliar techs who do not follow the guidelines and add X and then warm the engine and then recheck before topping off.
Old May 31, 2022 | 12:02 PM
RDT-G23's Avatar
2022 AMG GLE63S
Exactly. All these techs do is stick a bulk feed gun into the fill hole and hammer in the stipulated capacity. This is why I don't take my vehicles to outside sources for PMs and this is also why I wish the vehicles had dipsticks as a redundant measure to immediately ascertain levels/avoid overfilling/partial (messy) draining.
Old May 31, 2022 | 04:33 PM
mikapen's Avatar
That's not the procedure any more. The drain plug is also a "fill to overflowing" plug that should be hard to defeat - if it's used.
