Jack up the GLE? Spare Tire? FORGET IT!
I’m not sure about a portable tire lifter, but you must have the pins. Who knows why the krauts do this (use bolts versus studs and lugs) but my M5 was the same. It is hard to do a tire wheel change without the pins…
Get two.
The title says M15x1.50 but the text correctly identifies it as M15x1.25.
I need to find the Emergency Jack kit for my GLE, the other is missing from the previous owner. all that is left is the tow bolt, the spare tire, the air compressor with the slime. and that's it.
The inflatable spare is heavy enough that I haven't taken the time even to lift it out of its home, much less try to fit it.
But my spare is MUCH wider than the previous temporary (inflated) P155 tire.
Now that I think of it, I need to verify that I have the correct bolts for the spare. The old spare (164 - 166) needed different bolts.
Does anybody know if the new GLE 53 spare uses the same bolts as the road wheel?
No, I haven't removed the spare liner. No, I haven't bought a lot of other tire/wheel sizes and tried fitting them. Yes, there seems to be a lot of space under there, and removing the liner might gain 2" or more in diameter. My inflatable spare is 10" wide, and it fits under the floor. There might be another inch or three with the liner removed. To repeat: No, I haven't tried it yet.
Here's my spare - '21 GLE53 SUV, 21" wheels.
