12V Battery malfunction twice in a month
The first time it happened, I couldn't start the engine. The instrument cluster had a big red battery icon and message "see operator's manual". I had to get it towed to dealer. The dealer then told me it was a software issue and they fixed it by a software update. I took it home but two weeks later the same problem happened again! Now the car is towed to dealer again and I'm waiting for response from dealer.
I'm afraid there is bigger problem hidden in the battery system. I can't imagine this happened to such a new car. Has anyone seen the same problem? I'm wondering whether it is the 48V battery or the 12V battery. I've heard of many issues with the 48V system but mine shows "12V battery malfunction" on the dashboard.
It may have been a software issue that caused the battery to discharge the first time.
And it's possible that the software fix solve the charging problem.
However, if a battery is in a zero state of charge for a prolonged time, that may have killed it, I'm unable to take much of a charge or store it for long.
I would ask them if they load tested the battery after you're fix, or if they should do that before they do anything else
Good luck with this.
It does sound like a 12 volt problem, because I think there's a separate warning icon for 48 volt. When you push the start button into position one and all the dash lights light up, I think you see both 12 volt and 48 volt icons.
It's too bad that we don't have more info available from our displays about the state of charge of both batteries. In my '19 CLS53 at least there is a display that shows how much the battery is being charged as I drive. From this, one can infer that the battery needs charging or not. It would be better if we had a display that showed the state of charge directly for both batteries.
If this happens third time I'm going to sell it and switch to a more reliable brand.
Also searching the owner's manual in car, nothing comes up when I seek for "48v."
has the issue this issue been solved by MB?
My 6 month old 2021 GLS63 had :
red battery sign
See operators manual
Pop up.
Had to tow the vehicle to MB dealer.
still waiting for diagnosis.
Any input on what the fix is?
Thx
What freaks me out is that based upon the messages, this can occur while driving...
Cheers,
