Oil change steps: 2022 AMG GLE53
Old Jun 14, 2025 | 12:35 PM
  #51
coachhomer's Avatar
2021 AMG GLE53
Good afternoon all. So I did my second oil change today on this car and I was only able to get about 7 quarts of oil out. Interestingly 10 quarts went in and I checked the engine oil level and it said it was good. Is there a low oil indicator on these cars?
Also, I was mulling around in the engine and noticed that there is a crack in the lip of the coolant reservoir. I will bring this to the dealers attention but is it of immediate cause for concern?
Thanks!
C
Old Jun 14, 2025 | 02:33 PM
  #52
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
Yes, the car oil sensors will warn on the dash if the oil level gets too low. If you did not see a warning message, you are probably just fine. As for the coolant tank, yes replace it asap. Air leaks are no bueno for the cooling system.
