Oil stain on the top of the engine M157
Old Jul 19, 2022 | 09:18 PM
///ASN's Avatar
GLE 63s
Hello,
May I ask what is the oil stain on the right of the engine (when you stand in front of the car)?
I am looking to buy a used GLE 63s and I found quite a lot of them having the same oil stain there
is it caused by the timing cover leak?
Old Jul 19, 2022 | 09:57 PM
Frenetic's Avatar
2025 AMG GT 63
Those tubes look like the outlets for the turbos to an intercooler. I think right next to those tubes under the plastic housing are some oil return lines for said turbos and the waste gates. In fact, I think one of the turbo impellers is just north of that tube, which means there’s a lot of oil pipes, tubing and the turbos themselves, all filled with oil, very close by.
However, I say this with caveats as I’m not familiar with this engine, but I am familiar with BMW V8s, which I had, and it, too, was a hot-vee setup.
Old Jul 20, 2022 | 09:44 PM
chassis's Avatar
2017 GLE350 4MATIC
Pull off the engine cover and look closely with a bright LED flashlight. Front cylinder head covers are common leak points from the factory. Dealer can reseal them and they generally stay resealed.
Unlike the BMW V8 mentioned in the previous post, the M157 is not a hot vee architecture. It uses traditional exhaust manifold-mounted turbos.
Old Jul 21, 2022 | 09:00 PM
amg guy's Avatar
2024 GLE 63 S Coupe 2020 E 63 S
I’d be willing to bet that oil is dripping somewhere around the pulleys and is getting flung on to the turbo inlet pipes. I would say it’s either coming from the camshaft adjuster solenoid’s or the camshaft sensors or even worse possibly the valve cover gaskets
Old Jul 21, 2022 | 09:16 PM
T_D's Avatar
T_D
GLE
I’m in the market as well for a used gle63s coupe. I will keep an eye out for this ..thanks and let you know if I find out anything.
Old Jul 21, 2022 | 10:24 PM
amg guy's Avatar
I have a 2018 GLE 63S coupe in black that im
selling. 46,000 miles. Full CPO mercedes warranty until march 2023. Can buy 2 more years to extend that to 2025 if wanted. $74k
Old Jul 21, 2022 | 11:03 PM
T_D's Avatar
T_D
GLE
A bit too many miles than I was looking for…is it a porcelain white and black interior? Thanks
Old Jul 22, 2022 | 12:47 AM
amg guy's Avatar
Black on black. Carbon weave interior panels. Gray accents. Just about every option on the car. $122k msrp
Old Jul 23, 2022 | 06:51 AM
Frenetic's Avatar
2025 AMG GT 63
Yeah I didn’t realize MB’s V8s are traditional in the sense that the turbos aren’t in the valley but on the outside, meaning the exhaust manifold is normally placed instead of reversed for a “hot vee.” That means that tube is likely the intake after the intercoolers, and I have no idea what’s under the plastic.
Maybe it’s not necessarily oil but more charring/burning.
Old Jul 23, 2022 | 11:37 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Well, that depends. The newer V8's use the hot vee turbos but the M157 uses a traditional turbo setup. The oil looking stain could be from belt wear. Just about every 157 engine has it and it will typically wipe off. Could be oil but that was not the case on my M157.
Old Jul 23, 2022 | 11:57 AM
Frenetic's Avatar
2025 AMG GT 63
Yeah if the top of a drive or accessory belt is right there under the plastic than yes, it could be grime and other stuff kicked off the belt. It also makes sense in that it’s predominantly on one side, which I assume is based on the belt rotation.
Old Jul 23, 2022 | 02:49 PM
mikapen's Avatar
Yeah I didn’t realize MB’s V8s are traditional in the sense that the turbos aren’t in the valley but on the outside, meaning the exhaust manifold is normally placed instead of reversed for a “hot vee.”......
There are pros and cons to using a hot V. One of the cons is that you can't use the big turbos, which have more lag. And one of the pros is that you have a shorter exhaust path for less lag.
The 63S gets the best of both worlds: Big turbo for max power, and EQ boost to eliminate lag.
Old Jul 25, 2022 | 01:22 PM
Todd Edwards's Avatar
2016 MB GLE 63 s 4matic coupe
How much do you want for your 2018?
Old Jul 26, 2022 | 01:26 AM
amg guy's Avatar
$74k obo
Old Jul 26, 2022 | 04:26 PM
$74k obo
where is the vehicle located?
Old Jul 26, 2022 | 06:54 PM
amg guy's Avatar
San Diego
Old Oct 11, 2023 | 07:13 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
Originally Posted by ///ASN
Hello,
Sorry for rejuvenating the post but the oil staining you are seeing is likely from the oil cooler housing which sits beneath that inlet tube. These, unfortunately, leak almost all the time. Even if you replace the gasket they will start to leak again. It’s best to just try and keep that area clean.
Old Jul 27, 2024 | 11:08 PM
jcarsnz's Avatar
The staining on the air intake pipe is from a leaky Active Curve Pump.
https://mbworld.org/forums/gls-class...gls-550-a.html
