Figured out a good exhaust solution for my 63
I added an x-pipe and two hollow core mufflers so I doubt there’s any significant increase in restriction.
Much smoother. Reminds me of oem sound level- ish, which is awesome for a 5500lb suv that is probably creeping around 800hp. No rasp and again, a smooth exhaust note .
https://i.imgur.com/bLA8fTI.mp4
https://i.imgur.com/K7ASBrs.mp4
If you remove cats, you should DEFINITELY add an X-pipe. If you want loud, don't install the two mufflers I did. Or do shorter ones.
IMO, just removing the cats sounded pretty bad unless it was high load and high RPM. Part throttle and low rpm were awful.
