Engine Code Help
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Howdy Folks,
I've been a member for ages but can't recall my login, as such just signed up again. Anyhow's I'm about to purchase a GLE63s 2018 Model from Sydney and the dealer just sent me some engine codes, then claimed it was for the aftermarket steering wheel that's fitted. (It has a Aftermarket steering wheel, with LED lights and what looks to be an LCD display apparently from Japan). I am looking for any info on these engine codes:
C01EB00 - There is an internal fault in control unit "N30/4 (Electronic Stability Program control unit)" - ESP - Electronic Stability prog ram (N30/4)
C015100 - There is an internal fault in control unit "N30/4 (Electronic Stability Program control unit)" - ESP - Electronic Stability prog ram (N30/4)
C015200 - There is an internal fault in control unit "N30/4 (Electronic Stability Program control unit)" - ESP - Electronic Stability prog ram (N30/4)
B21059A - The capacity of the starter battery is too low. The operating conditions for the component or the system are not satisfied - SAM - Signal Acquision And Actuation module (N10)
Greatly appreciate any more insight folks can share.
