Anybody running out of washer fluid too often?
"Kristall Klar was formulated to be easy to use in dealerships and mechanics shops - both of which use regular tap water. For this reason Kristall Klar has soft water conditioners in it so it can be used with regular tap water. This prevents hard water minerals from clogging the spray jets and causing wear and tear on the windshield washer pump. If you have well water, we recommend using distilled water."
So Distilled water is fine with this brand. I prefer it as I have very hard water in my area and want to reduce any chance of scale to clog the jets. Gallons of distilled from Walmart is pretty cheap.
https://nextzettusa.com/windshield-washer-fluid-kristall-klar-8-5-oz-250-ml/
