Anyone with a GLE 63s Coupe w/ Tow option ??? Please Help
I wondered what the difference was between A1663100200 and A2923100037 which is what is supposed to be the only tow bar that is compatible. Nice to know it fits.
I’m assuming you also installed the MB tow module with the wire harness? Did you have the dealer install it?
Nice Wheels BTW 👍🏼
- AMG Smart Protection: Modern Mercedes-AMG models are built with intelligent transmission protection systems. They usually won’t allow downshifts that would push the engine past redline. So even if you pressed something, the car probably limited it
- Short Duration: The high RPM only lasted 1–2 minutes, which isn’t ideal, but engines are designed to handle those revs occasionally — especially performance engines like the AMG V8.
- No warning lights: or any warning messages or odd behaviors after switching back — which is a great sign.
- Listen for any strange noises, lags in shifting, or warning lights. If everything feels normal — you’re good.
I am kind new to MBWorld and not too savvy on roaming around this website to post the new topic yet.
Again, Warm Regards,
