Another Fog Light Question
2010 GLK, Steel Grey, Premium Package
I tested the fog lights on my GLK this morning. To my surprise, only ONE rear fog light (the LEFT one to be specific) comes up. No matter how I turn it, the right one never lights up. Does your GLK act the same way?
PS. The two front fog lights lit up at the same time.
I think that might have to do with what side steering wheel is on. I've seen this on many other cars, where only left one is on. Kind of annoying I think.
I haven't tested them on my GLK yet, so not 100% sure if above statement applies to GLK.
GLK350-premium pks,Bi-zenons,NAVI,OEM Hitch, Stepboards etc..
Not sure but in "Reverse" then should be on
I just tried but it's the same thing even in 'reverse'. I've also searched some other forums it seems most German cars or European cars all do that because if both rear fog lights come up it will confuse cars behind you as they might think you are braking.
And please do NOT drive with your single rear fog lamp on unless it is foggy outside. Its annoying during normal evenings. That is designed to be driver-only in heavy-fog only, to illuminate the passing side of the vehicle so faster moving cars do not run into you.
In order to avoid this, pull the light switch until the first click, that's when front fogs come on. If you pull further then rear single fog will come on as well.
I finally figured what every light switch position does lol
Had light switch on manual fog one time, and parked car. Didn't realize the light was on all the time. Luckily got back before battery ran out.
Hey all... I just switched from the bimmerboards to this one. I sold my 03' 525i to pick up a 03' C240. Anyways I did my first search to find out how the fog lights come on and I hit the nail on the head with this thread LOL... I'd hate to start out by asking simple questions without searching first.
I was taking night images of our GLK's lighting when we first got it and I noticed that. My MINI Clubman has the fog light in bottom of left tail lamp and the reverse light in the bottom of the right. On several occasions, I've had to inform other MINI owners that one of my reverse lights isn't out. I guess it will be the same with the GLK fog light(just hasn't happened yet).
