Looking for 17" wheels
Old Jul 24, 2009 | 06:00 PM
retrop's Avatar
2009 IS-F, 2013 GLK
Is anyone upgrading from their standard 17” wheel for an aftermarket option before delivery? I’m looking for a dealer who might have some ‘take off’ 17” wheels in stock for my winter tires.
I have 19’ wheels and don’t want to purchase 19’ snow tires!
Old Jul 25, 2009 | 09:16 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
I'm not sure what you mean if anybody is upgrading, cuz 19's are standard wheels in US (and Canada I believe). Just pick up some cheap decent looking 17's from tirerack (110-140 bux per wheel). MB wheels will run you a lot more than this.
Old Jul 25, 2009 | 12:02 PM
Baby G's Avatar
GLK 350
You can also try ebay if your looking for a used set with the CORRECT offset that will fit. I bought used 18" Infiniti G35 wheels from ebay which fit the current G, and had the snows on them.
Old Jul 25, 2009 | 03:38 PM
MilesBFree's Avatar
GLK
I am taking off the 20" wheels that come stock as part of the Appearance Package. PM me if interested, as I will probably have them up on eBay in the next week or two.
Old Jul 25, 2009 | 08:30 PM
retrop's Avatar
2009 IS-F, 2013 GLK
I thought 17" wheels were standard on US spec GLK. I guess I am wrong. I did check tire rack and they didn't list available 17" wheels for the GLK. What offset do I look for? Are they the same as the C-class?
Old Jul 25, 2009 | 10:58 PM
rdef1's Avatar
GLK 350 4Matic
Some one posted on another GLK tire thread that you could use the C350 as a base when you are checking out 17 in tires on Tire Rack.
Old Jul 26, 2009 | 11:36 AM
NYCGLK's Avatar
I'm pretty sure tirerack gives you 17's as one of the optional sizes for GLK 4Matic. Start with tires, it'll give you 235/60/17 as an optional size, and then look for wheels for those tires.
Old Jul 27, 2009 | 11:56 AM
Baby G's Avatar
GLK 350
Winter Tire size recommendation:
17" Recommened: 235/60 - 17
Vehicle: 17 X 7.5 (4)
Offset: +35mm
18" Recommended: 235/55-18
Vehcile: 18X7.5
Offset: 48mm
Old Jul 27, 2009 | 12:32 PM
NYCGLK's Avatar
it's odd that these wheels have 13mm offset difference even tho they are identical in width, but i guess since they are more narrow you have more room and can have wider range of offsets. I'd go with something closer to +45 (stock offset) as the width of the tires is still the same as the OEM tires.
Old Aug 3, 2009 | 09:37 AM
jrct9454's Avatar
'14 GLK250 Diesel
Any wheel that will fit a W204 C-class will also fit a GLK. Which means you have dozens of choices from TireRack and other sources....just specify a C350 as the "search" vehicle, and take your pick.
