vibration in the gear shift knob when shifting up?
GLK 350
Hi All,
I picked up my GLK last Monday and have noticed when driving and shifting up, if I have my hand on the gear shift knob, there is a noticeable vibration when it is shifting up. It is most noticeable from 1st to 2nd and 3rd.
Any other GLK drivers notice this, or if not, what are your thoughts?
Other than that... I have to say I'm lovin the new ride!!!
Cheers
Cheers
GLK 350 4matic
Hi All,
Cheers
Cheers
M-B GLE, Porsche 911 Turbo, Porsche Boxster (spouse)
If you were also feeling something through the steering wheel, I'd probably think about asking the dealer to rebalance the wheels followed by a look at the motor mounts if that didn't do the trick and then the control arm bushings next.
But since you're only feeling a slight vibration through the shifter, I probably wouldn't be concerned unless it worsens. If it does, they'll probably start by taking a look at the shifter vibration isolation mount (elastomer grommets) to ensure they were installed properly.
silky smooth here (at least to my standard), and I do keep my hand on the shifter often and even use manual mode once in a while (miss stick).
