For Canadians - brake dust easy care
Jeep Cherokee Laredo, 2010 MB GLK 350
Members here have recommended Carnuba and Rejex. I've also found the following available in Vancouver - see replies to my email below:
1. Thanks for your inquiry about WheelWax.
Yes, WheelWax will help you reduce your brake dust and make your alloys easier to keep clean. The reason is WheelWax doesn't allow the brake dust to attach to your alloys.
You can buy it from Volco Tires and Wheels, 12291 Bridgeport Road, Richmond, BC V6V1J4. Call ahead to make sure they have stock at 604-270-4727.
If they don't have stock, you can always buy it from my secure website www.wheelwax.ca.
Sy Langer
Ultimate Transportation Products
416-580-7327
www.wheelwax.ca
info@wheelwax.ca
2. Thank you for contacting the Dupli-Color website.
You can apply this product to alloy wheels, but first we'd recommend cleaning the surface thoroughly, allow it to dry completely, then prime with either our DAP 1690 Self-Etching Primer (preferably) or the CP 199 Adhesion Promoter. You can then topcoat with the Wheel Coating color of your choice.
Thanks again for your inquiry.
Regards,
Eric
Canadian Tire
Dupli-Color High Performance Wheel Coating CHWP 104 High Performance Satin Black
Bar code 2691610400
Sy Langer
416-580-7327
www.wheelwax.ca
info@wheelwax.ca
Regards,
Eric
Canadian Tire
Bar code 2691610400
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
90% of wheels today are silver with clear coat... the same clear coat used on 90% of the cars... (except MB, Porsche, Audi, VW, Bu, Lambo, these cars have a new nanotech clear... etc... okay so maybe it's 85%).
That fact is ANY good quality car wax (even a good quality cleaner car wax) will work just fine on your wheels... just make sure not to wax them until they have been cleaned with plenty of mild soap and water and well dried.... no need for any "special" wheel wax.
When was the last time you were able to wash-off Tar from your wheels with mild soap and water? The point of using a good wax is to make the cleaning and upkeep easier.
A "Cleaner" wax, such as Mothers Calif.Gold Carnauba Cleaner Wax has a small amount of polishing compound blended in. This helps remove stains and blemishes, even tar without harming the clear coat.
The point is, there is no reason to buy expensive waxes that are so called made for wheels.... even polished alum. wheels.... they're all clear coated. But if you're happy paying more... then be my guest.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
