GLK 350 Performance Upgrades
The big question I have is would a 6.3 AMG engine fit in the GLK or even a 550 V8. I would be up for a conversion.
i would love to fit the amg engine in mine!!
this guy clains the video is a brabus glk? http://www.youtube.com/watch?v=GH-rc6HjURg
From the article:
They’ve gone and done it; the tuning gurus at Brabus have stuffed a V8 engine in the new GLK SUV. And as though replacing the V6 with a larger and more powerful V8 powerplant weren’t enough, Brabus had to go and modify the entire thing.
Brabus engineers completely rebuilt a 5.5-liter motor (as found in vehicles like the S550) and increased the displacement to 6.1-liters. The modifications involved a larger bore and a longer stroke, with a lighter crankshaft, stronger pistons with a compression ratio of 11.0:1 and a modified cylinder head with larger valves and new cams.
In total the new engine makes 456hp at 6200 rpm and 453 ft-lbs of torque at 3100 rpm. Brabus says the V8 GLK can hit 62 mph in just 4.9 seconds and blast on to a top speed of 172 mph.
Other modifications on the car include a lowered suspension (1.2-inches), 21-inch Brabus Monoblock F wheels and a big brake upgrade. The new brake system uses six-piston front calipers with 14.2-inch rotors and six-piston rear calipers with 11.8-inch rotors.
Technically, this Brabus GLK is also a Widestar, meaning that it features the Widestar line of aerodynamics, including a new front fascia that reduces lift and, of course, those flared fenders.
If you need to ask how much, you can't afford it.
All I'd really want is a Kompressor system for the GLK and the kleeman upgrades to get it over 400hp. That would be sick, especially with the Brabus widestar package.
to change the entire engine just to make the car go faster isn't worth the money becuase with it all added up you couldgo buy an amg plus it is not entirly realistic for every person who wants to upgrade performance to their glk
good idea
just really expensive
I think I'll take a look at the kleeman upgrades
those interest me
but another to look at is the sroung booster USA
it's a little battery looking object you but behind your gas pedal and it increases the coil reaction time needed to make the engine go
so basically increases 0-60 without any engine uprages or anything expansive
cost about 300 and it's an easy plug in and play thing
take a look at it
good idea
those interest me
take a look at it
Camshaft upgrades are not cheap. Those Kleemann upgrades will cost you over $10,000 when labor is added. For that price, you can buy a 550 motor, ECU upgrade it, install it in the GLK and still be faster than any other GLK upgrade can offer.
but I am probably going for the kleeman upgrades
and does anyone know where to get thr black grill from the glk rally car
From the article:
upgrades:
20" AMG rims
Z-Rated performance tires
front tires= 235/45/20
rear tires= 255/50/20
K&N Oil Filter
K&N Air Filters
Magnaflow exhaust system and tips
lowered ride height (-2.5") & tightened suspension
+ sway bars
weight reduction= est. 900 lbs. off
Brembo brake pads
custom grill & hood scoop for cooling
factory = 268 hp @ 6,000 rpm / 258 tq @ 2,400 rpm
mine = 330-335 HP @ 6,000 RPM's / 285-290 FT-LBS TQ
factory weight = 3,926 lbs.
mine = 3,000 - 3,100 lbs.
with my under the hood upgrades , tires , lowered ride height, etc. keep the traction control turned off and in sport mode, and shift myself.
thing is a BEAST ...so much fun .
Handles very well.
70+ MPH on windy mountain roads (30-35 MPH posted signs)
About the motor swaps...
I have a 1998 E320 4MATIC Wagon...
with a 5.4L Supercharged V8 (55 AMG)
motor was from a '99 E55 AMG Sedan
350 HP , 400 FT LBS Torque
18" AMG Monoblock II's - 225/45/ZR18
5 speed AWD (722.6 4MATIC)
*** 0-60 in 4.6 seconds ***
the station wagon that will make your "sports car" look stupid...
