Tachometer Getting Up to 7.5k RPMs When Accelerating
How is your transmission shifting: harsh shifts, shifting at the correct rev points? What gear are you in when the engine hits 7.5K? How are the shifts when you shift manually?
You mention that you've had a fluid change, that would have been my first guess. Is the fluid level correct? Other possibilities might be the solenoid or the tranny speed sensor (both should throw a code but...).
I would get an MB-specific code scan to see if anything shows up. In the meantime drive your car as little and as gently as possible and use manual shifting to limit the revs.
Good luck
One other (extremely) off-the-wall thought. Does the engine sound as if it's doing 7.5K? It should sound and feel really strained. If not, maybe your tach is giving you bad info.
Good luck
Even in sporty driving, there's no reason to rev it past 6k rpms if you can help it. Either it's tuned somehow without you knowing it (previous owner) or something's up with the electronics: could be the ECU that controls the shift points or the instrument panel controller(s) which may be on separate CAN gateways (ie, individual computers).
Good luck.
Good luck.
You shift up as you gain speed, shift down as you slow down. You can also shift down to create engine braking (useful for long steep hills).
The paddles will momentarily place the transmission into “manual” mode, where you will HAVE TO change each gear, but will resume full auto if no further input is received (I think 30 seconds tops).
Try it out when you get a chance, it’s not bad at all.
You can keep the revs down by going down one gear manually (like from 7th to 6th) before you start passing, and then shift up back into top gear at your desired RPMs. I think 4-5k is probably more than enough.
I do it all the time on Moose and he’s a diesel, which means he revs at much lower RPMs and 4.5k is his redline basically.
