Turn Signal Bulb Question
2017 GLC300 4Matic SUV
I know this is a dumb question but does anyone know how to remove the bulb out of the turn signal holder? I want to change that bulb to the equivalent white bulb (that still flashes in amber) so I don't have that "fried egg" look. I know how to access the turn signal bulb and remove it from it's location in the car but getting it out of that holder is my problem. It's probably simple but I don't want to break anything. BTW, the manual says it's a PY21W bulb which would be easy to remove but it really is a 3357A bulb which has clips, for anyone who wants to know.
I just found out that you need to pull them out with a little force, The way it locks in I was surprised they come out that way. You kind of have to rock them a little. I went to the Mercedes dealer and they showed me how.
HI, i am also interesting in doing the same job to change to the xexon light, but i am wondering did you have the regular lights before you did this? and did you do it by yourself or go to some place to help you out, because i am going to Chicago next week and i am planning to change lights there, do you have recommendation which place could do that? oh, by the way, how much you pay for the whole things.
i know there lots questions , thank you .
Hi, yes I had the stock Halogen lights and bought an HID kit online at www.buyhidkits.com and paid $75.00 for the whole kit. I bought the H7 6000K kit because they match the white color that the Mercedes with Xenon have in my opinion. I think the kit is less expense now at $57.00 but you would have to check it out. Also, don't buy the relay ($14.99) it's not needed. I had a local store near my home in Orland Park, IL called Mobile Concepts install my kit for me and that cost $150.00 so all together it ran $225.00. You have to call and make an appointment at 708-226-1100. They were willing to do my install even though I bought my own kit online. I really like the HID lights and do not regret doing the switch.
2010 Barolo Red-Almond/Black GLK 350, 2008 Cadillac Gold Mist LUX III DTS
Bear with me. I know very little about HID kits. Well, actually nothing.
But, are you sure they are HID?
That ($57) is very,very cheap for HID lights.
And where it says H7 60000K......H7 is the kind of bulbs you had to begin with....that is Halogen.
I wouldn't mind upgrading to HIDs, but thought it would cost me maybe $1000.........
Trust me, they really are Xenon lights. My kit came with the bulbs, ballasts and hardware for the install. As far as your point about the bulb, when you order them you have to know what original Halogen bulb you have, otherwise they would only make one Xenon bulb for all cars and they don't. I believe the type (H1,H2,H7, H11, 9004, etc) has more to do more with the type of connector it uses. The GLK fogs are H11 and have a different way to connect the plug than the H7 for example. I know you can spend anywhere from $50.00 to $400.00 for an HID kit, don't ask me why. Mine have been installed since November and I have not had a problem.
2010 GLK 350 Sandstone Beige
You do not need to change any of those bulbs, I just did it because I did not like the yellow stock color. I changed the parking city bulb and eyebrow bulb to these LED bulbs:
http://store.ijdmtoy.com/Canbus-Euro..._t10_sku27.htm
I also did all my interior lights to LED. If you click on my name and view my profile, you can view my pictures.
High beams: I rarely use the high beams so for this bulb all I did was replace it with a Halogen H7 55W bright white intensity bulb (which is a blue color bulb). It's not quite as intense white but better than the stock yellow. When the parking lamp is on it reflects a bluish color which I like.
Fog lights: Yes, they are H11 bulbs and I found out by searching this forum. I have not changed them yet, still deciding. If you want them to match you would need a H11 HID Xenon kit. I am hesitant because the fog lights bulbs are very hard to get to. You have to remove the front drivers side tire for that bulb and you have to lift the car to get to the drivers side bulb. Not something I want to do because I rarely use my fog lights anyway. Maybe during the summer when I get bored.
You do not need to change any of those bulbs, I just did it because I did not like the yellow stock color. I changed the parking city bulb and eyebrow bulb to these LED bulbs: http://store.ijdmtoy.com/OBC-Error-F..._t10_sku27.htm. I also did all my interior lights to LED. If you click on my name you can view my album for pictures.
Exactly, i just check the interior lights, how do you change the lights in the center above the rear mirror, i even can not open the cover, also the light above the back seat? those cover are so hard to open, maybe need special tool to do that?
view these links and search this forum for a thread called "dome lights removal". There used to be pictures but you can read what was said.
https://mbworld.org/forums/attachmen...g-p1010077.jpg
https://mbworld.org/forums/attachmen...g-p1010048.jpg
Can you tell me what parking city bulb and eyebrow bulb you have. The link isnt working. I want mine to look the same as yours and Im also getting the hid kit for the fog lights. Thanks for all the info.
I have the Xenon white color.
No problem, the LED bulbs are the same for both, this link should work:
Just ordered all my bulbs. HID kits for the headlight and fog lights. LED lights for the eyebrow and the parking lights. Also the Halogen H7 super white for the high beams. Total cost with shipping 250$.
Im going in for oil change soon should I ask my dealer to install the lights. Am I going to pay more to have them do it? Please give me any advice.
To answer the question above i believe halogen xenon lights are just better halogen lights that look like xenon hid lights. They plug in like your normal halogen bulbs.
hi, thanks for answering, i also order all the bulbs. seems those cost me around $350, i did not order the HID kit for the fog light, just order halogen xenon light instead, since i consider i am going to use that too much, but i am going to replace all the halogen bulbs for the interior lights and license plate light.
I personally do not wanna go to dealer to do that, they will definitely charge you. go to a reliable custom shop, they should had such experience, that is what i am gonna do.
I would check with your dealer just in case, but I would be surprised if they would want to do it. CXPU is right, a good custom shop would do it. I paid $150.00 to have a custom shop install my HID kit and did the rest of the bulbs myself. If you can get them to do it for a reasonable price it's worth it. The bulbs are a real pain to get to.
It would be cool to rewire the blinker to the marker light in the eyebrow (one that stays one and also blinks when blinker is on). This way you could have eye brows on like on C-Class and they would also blink in amber if you use one of those dual color LEDs.
Why would you put in the dual color (white/amber) replacement when it would just be off and turn amber like OEM did?
Unless these bulbs are always on white and blink amber no matter how the OEM bulb works, or you rewired it? These dual bulbs aren't cheap, bout $40 each so if you spent the money on them I'm sure you wanted the functionality.
Please explain. Thanks.
I simply put in a bulb that is silver but blinks amber. The reason was that the amber only bulb when it is not on makes the headlight housing look like a "fried egg" or reflects a yellow look. The silver stealth bulb when off looks white so the housing looks white. I just like the look, both function exactly the same and the cost was only $12.00. I purchased it on Ebay 3457 Silver Chrome Natural Amber Bulb
The turn signal light you are referring to in the manual as PY21W isn't normally on and only blinks when turning.
The questions is, who will be first to take the orange side marker out.
Why couldn't they make it separate like on C class and not built into the headlight?
gdepau, thanks for posting that pic in your album of the white and and amber turn signal both on. I had a few questions left I just wanted to verify.
1. Did you change those out or are those OEM? If changed, are those just White Halogen bulbs?
2. This is the bulb you said that you bought with the silver glass that lights up amber so it doesn't have the fried egg look when lights are off.
3. These are LED replacements, are the ones you have white or blue?
And finally is your HID light OEM or aftermarket?
THANKS!!
THANKS!!
