Lower the Open Tailgate an Inch?
Old Feb 27, 2010 | 12:08 AM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
Is it possible to lower the height of the fully-open tailgate only an inch or so? I know it is possible as described in the owner manual to lower the full-open position 8 or more inches. But I just need it an inch lower when open to ensure that it does not hit my garage door frame if I totally screw up and back out of the garage with the tailgate open.
I seems that the opening height is limited by the full extension of the gas-filled "shocks" rather than a separate bump stop. But there is no way to limit or adjust their travel extension. Perhaps the motor drive has an adjustment or there is some other way to limit the upward travel by a small amount.
Any suggestions would be greatly appreciated.
Old Feb 27, 2010 | 10:05 AM
Dreamka's Avatar
GLK350-premium pks,Bi-zenons,NAVI,OEM Hitch, Stepboards etc..
as it is described, minimum is 8inch.
I've also tried to open just in 2~4 inch but wasn't possible.
Old Feb 27, 2010 | 11:28 AM
yualfred's Avatar
GLK 350 4matic
Same issue as I had. It cannot lower by 1-2 inches. 8 or more is too low my head will hit the door when its open. I was thinking of adding a mechanical stopper myself, but hadn't have time to look into it yet.
Old Feb 27, 2010 | 01:44 PM
EnigmaAW's Avatar
2021 G63
i'm assuming it's not power?
Old Feb 27, 2010 | 02:46 PM
slk55er's Avatar
It is powered. It appears that the final inch or so of upward travel is not really powered, per se. Rather it is simply motion due to the final extension of the gas-filled shocks.
I'll see if I can figure a way to mechanically limit the final travel of the gas-filled shocks or use a bump stop on the hinges.
Old Feb 27, 2010 | 04:16 PM
RedRover's Avatar
2010 Barolo Red-Almond/Black GLK 350, 2008 Cadillac Gold Mist LUX III DTS
If you guys find a mechanical way of lowering the hatch opening by an inch or two, please come bak here and post about it.
Mine is not powered, but my wife, 5 foot nothin', can't reach the handle. I had to rig a rope so that she can close it.
Real classy.
(She had no problem with our 2003 Murano, an SUV that was larger)
Old Feb 28, 2010 | 08:29 AM
EnigmaAW's Avatar
2021 G63
have you tried calling your MB dealer and seeing if they can adjust the range on the motor?
Old Feb 28, 2010 | 07:56 PM
slk55er's Avatar
I have not asked a dealer. I have decided that it is not feasible to put a mechanical bump stop at the hinges -- the sheet metal on the roof is simply not strong enough to prevent the tailgate from rising. (Don't ask me how I know.)
I do note that on the side frames of the tailgate opening below the mounting point for the "shocks" there is another hole which could serve as an alternative location for the shock if there were a mounting pin there. This would lower the tailgate. Alternatively, shorter shocks (say 19" vs 21" or so) might serve the same purpose.
BTW -- Look for some photos of our GLK in Zion National Park that I'm going to post.
Old May 3, 2010 | 06:37 PM
krou's Avatar
GLK350
Real classy.
I have the same problem. My wife is not able to reach the tailgate. So the salesman at the dealership suggested to use an (Mercedes Benz)umbrella (that he gave for free). So we leave the umbrella in the trunk. Whenever she wants to close the hatch, she pulls it down with the umbrella hooked to the handle inside the door.
Old May 31, 2010 | 01:16 AM
QSHIP's Avatar
GLK
This is an issue about the hatch for short people like me. once it open you need something to bring it down. Does MB knows that not all people are created equal?
