Anybody debadged?
Thanks for the pics...I could not find pic of rear of my car...lol
P.S. I really like the GL-style exhausts on the bluetec GLK.
I've thought about de-badging my CL as well, but I wanted to photoshop it first and see what it would look like.
As such, I haven't had the time to do it. I suck at tEh photoshop, so it would probably take me 2 hours just to figure out how to select a brush. :/
If I do de-badge it, I don't know that I'll remove the fender badges. I always get a chuckle from seeing the look of passengers in cars that pass me on the highway. Most of them who see the fender badges do a double take at them once the "V12 BITURBO" badge registers in their heads.
One of these days though...
GLK 350 4Matic, G35, Ford Ranger FX4II
De-bagging
Use dental floss (I'm serious) and a back and forth motion under the badge cutting through the foam backing, then Goo-gone to clean up and a good waxing. Your done. Dental floss is awsom for cutting through badges.
Cheers
Cheers
1 Post
His mama. Traded y0 mama in because she was squeaking.
I used a combination of Dental Floss and a digital heat gun on uber low setting. Well, medium uber low.
Clean-up was minimal with this method. I just need to wax the rear, as you can see a faint "5", but that's just paint not being as faded as the rest, me thinks.
If I don't like it, I know a place where they have so many "CL65 AMG" badges, they sell them. At about 60 dollars a pop. :/
Anybody want a set of slightly used CL65 AMG badges? Guaranteed for an easy 50HP.
I am not touching the fender badges though...
#33
I'm hoping this would not be an issue on 1 year old garaged car. Thanks for tips, that's what I read before as well. Once I have some time I'll do this.
#34
1 Post
W205 c400 sport
Its nice to see some X204 owners customizing. All that i have seen are bone stock. I find these threads much more entertaining than the usual help threads. I have been spending most of my time here over on the W204 forum, they are doing everything to the car. Its nice that they are such close cousins as well, or are they brothers, you know what i mean.
#35
I just pulled the badges off my new GLK last night and it looks great! (Just the letters, COOPDOGG, so you can relax.)
I've done this to every car I've owned ever since they started attaching them with adhesive instead of drilled holes, and even did a few with holes when painting was required in that area.
I don't like Goo-Gone; it's essentially lighter fluid and I think it might be too harsh for the paint so I use WD40 for the clean-up.
Thanks for the dental floss trick; really saves the finger nails!
#36
I asked the dealer to leave off the dealer emblem that most dealers typically glue on. They were perfectly fine with doing so. Just a tip for new people looking to buy a GLK.
These are typically easy to remove as others pointed out above, but it is one less thing to hassle with if you ask before the dealer preps the new car.
They did add a dealer license plate bracket which was very nice as brackets go. It was even nicer when I took my p-touch labeling machine with white text on black weatherproof label, printed "McLaren Racing", and stuck it over the dealers name
We got the RWD version, so I don't have the 4-matic emblem on the right rear.
I have no strong feelings about the GLK 350 emblem on the left rear either way.
I would not remove the star on the back, personally.
As far as the front emblem goes, I find myself wondering if a person could retrofit the stand-up spring loaded star... Might be cool in a retro sort of way, especially since all of the past M-Bs we have owned have had those and I missed it at first on the GLK.
#37
1 Post
2011 GLK 350, 2008 Acura TL
Any pics?
#38
1 Post
#40
WD-40 is a combination of mostly mineral oil (petroleum-based) chemicals.
I would tend to think the citrus-based solvent would be safer, but at the end of the day they are both solvents. But citrus just sounds healthier!
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
I think either one is probably fine as long as cleaned off immediately. I would recommend washing the residue off with soap and water, and then re-waxing since both of these plus the soap will strip off most waxes.
#43
Goo Gone is based on citrus oil, not a petroleum product.
![Puke](https://mbworld.org/forums/images/smilies/puke.gif)
The WD40 is not very active but I agree it's best to clean it off and re-wax ASAP.
#44
Hey Blaze, was it hard to remove the grill and black it out and what paint/method did you use.
#46
1 Post
W205 c400 sport
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
debadging is really easy. i used a hair dryer and dental floss. you just heat up one section of letters and they pull right off. after they are removed i used goo gone to get rid of the leftover glue from the car. total time 20 mins. it a good idea to wax or buff the residue off. i did not and dust sticks to it ans you can make out characters, but after time it seems to have righted itself after a few washes.
painting the grill is easy to but take patience. there are grill removal guides floating around the c class section that should pertain to the glk. once remove there are a lot of finicky little tabs you have to seperate without breaking. i gave up on the tabs, i could not get one loose, then handed it to my brother and he finished it no problem
i used duplicolor paint, matte and gloss, fine sandpaper on the chrome, washed and dried. i came out great. just make sure you let the paint cure before putting it back together. if you look close on mine there are some thumb prints in the paint
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
this post is not very detailed, head over to diy section of w204 c class. there are step by step pics and tutorials for almost everything.
ps sorry for the grade school grammar, i just woke up, and this is easily my longest post here.
#47
keep the badges, you paid for it so be proud of what you have
born and raised in sindelfingen, germany for most of my life, going to stay true to what everybody in my family represents. everybody works at mercedes.
#48
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Goo Gone does not contain naptha, (so called lighter fluid). However, contrary to popular belief, Naptha will not harm factory paint either. In fact, it's prefered by auto detailers because of its rapid evap rate.
#49
It's not a matter of being proud of what I have; I prefer the cleaner look of no numbers and/or letters.
Thanks for all the Goo-Gone/naptha input. WD40 works fine since it is essentially a solvant (not lubrication, as many people erroneously think). Yes, I know, it's a Water Displacer, too...
