Bluetooth and the Radio
If I am reading the question correctly, yours has been working fine for some time but all of a sudden started to give those symptoms.
I would suggest unpairing the BB and re-pairing and see if that helps.
As part of the initial pairing process, the Comand and BB have to figure out which BT services are available on each other. One or the other device may have lost the appropriate services list or lost or corrupted one of the service definitions. (Note: this is hopefully an "English" explanation of what happens, even if I have some of the technical terms slightly wrong.)
By re-pairing it, they should sort out which services are available. Should be worth a quick re-pair to see if that helps?
My wife laughs when the car announces it has connected to "Crackberry". I would be disappointed if I had to change it, but good to know what I need to know in case mine ever gets hosed.
