Erase memory seat setting
2011 GLK 4Matic, Honda Pilot EX-L
I guess this may have been asked before but the manual is not helpful.
I'm 6'1" and when I try to program my current driver seat position into the memory, the seat moves into one that was perhaps set at the dealership suitable for a much smaller person. How can I reset this?
Thanks.
Thanks.
If the instructions bellow don't work, see your dealer:
(I'm not sure if there is a "reset" at all [Maybe disconnecting the battery for a period of time will reset it]. I believe you have to "override [new programming]" the present settings.)
Storing positions into memory
- Adjust the seats.
- On the driver’s side, also adjust the steering wheel and exterior rear view
mirrors to the desired positions.
- Press memory button M once and within 3 seconds press memory position button 1, 2 or 3.
When the settings are stored to the selected position, an acknowledgement signal sounds.
Recalling positions from memory
- Press and hold desired memory position button 1, 2 or 3 until the seat has moved
to the stored position completely. On the driver’s side, also wait for the steering
wheel and exterior rear view mirrors to move to the stored position.
i- Releasing the memory position button stops movement to the stored positions immediately.
- Adjust the seats.
