Cabin filter replacement
Old Oct 18, 2010 | 10:09 PM
CLK 2 GLK's Avatar
2014 ML350
Hey guys and gals I just got my service B done at House of Imports (239.00) with 100 dollar coupon good till end of october for anyone interested. My question is where is the cabin filter and how do you access it, I ask cause my engine is dirty and the only clean spots are the oil cap and windshield washer tank so it seems like nothing else was touched but those two things. Did I get hosed and all they did was the oil change, tire rot. and topping off washer fluid when they have a long list of B.S. they check.
I would like to check the cabin filter to see if they actually changed it so I need some assistance on where its at and how to pull it out.
Thanks.
Old Oct 19, 2010 | 03:51 PM
CLK 2 GLK's Avatar
2014 ML350
Old Oct 19, 2010 | 04:25 PM
DJ_VernonJ's Avatar
2009 Subaru WRX & 2010 C63
Thanks.
The item circled is your pollen filter, or in the MB verbage the "combination filter." Check to see if they billed you for 212-830-02-18. That is the part number. The list price of this part is $49.50. Installation should be pretty easy, with it's removal and installation being able to be done without the removal of the glovebox. I could be incorrect about this one... Anyone?
Old Oct 19, 2010 | 04:39 PM
CLK 2 GLK's Avatar
2014 ML350
DJ that is the correct part number on my invoice so now the question is did they actually change it ?. So who knows how to get to this and pull it out so I can see for my self.
Only reason I want to do this is it doesn't look like they checked all the things they are suppose to check like it says in my first post. For a 250 dollar oil change/cabin filter not so happy so I expect them to amuse me and check what is required to check per Mercedes guidelines.
Old Oct 19, 2010 | 04:43 PM
DJ_VernonJ's Avatar
The only way to double check this is to pull the filter out and double check it. Otherwise, it is really hard to say. If you know someone who is really good with cars have them do a once over. See what they have to say. If not, bring your concerns back to the repair shop. They should have a point check list, simple as for a copy. Does this help?
Old Oct 19, 2010 | 04:56 PM
CLK 2 GLK's Avatar
2014 ML350
How and where is it.
Old Oct 19, 2010 | 05:05 PM
DJ_VernonJ's Avatar
See the base of the filter? That is plastic. Simple climb under the dash, find that elongated covering and pull down on it. There should be a series of 4 tabs that you should be able to squeeze down, thus allowing it to drop out of the air box.
Old Oct 19, 2010 | 05:20 PM
CLK 2 GLK's Avatar
2014 ML350
Thanks DJ as soon as the wife gets home I will check it out and report my findings.
Old Oct 25, 2010 | 03:36 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Thanks.
Go here: https://mbworld.org/forums/glk-class...in-filter.html and look at post #13 for a link.
I wish you newbies would learn how to use the search tool.
Old Oct 27, 2010 | 12:35 AM
mr.mbenz's Avatar
GLK 350X :0
"I wish you newbies would learn how to use the search tool." - MBRedux
that's why you are here to help as always.....
