GLK300 Braking problem
My husband drives GLK 300 which was brought last year. As a 10-year experienced driver, he never involved a car accident on road before, but while driving GLK he had two small ones. He complains the brake was inefficient and it took longer than he expected to come into a complete stop.
Well, I drive it today and find the same problem, especially compared with Scirocco. I double checked the car and pretty sure it is not made by Toyota.
Do you guys think it is normal?
I have driven a few other cars thats heavier or have smaller brakes and definitely see no problem with the GLK's brakes.
Also be reminded that new cars come with EBD so the brakes dont just clamp at constant rate, it will brake in order to achieve a non sudden jolt effect.
My other car is a well-equipped G37 so it's not as if I don't have something to compare to.
What comes into play is how you brake. First if it is a panic stop you cannot pump the brakes. If you press very hard on the brake pedal you will feel the ABS system kick in. It actually pumps the brakes for you and you can feel it through the pedal. If you do not feel the slight vibration through the pedal then you are not pressing hard enough to activate them.
When they measure braking distance it is done in a panic stop where normally without ABS your wheels would lock up and you would skid. Most cars today have ABS and my guess is that your stop was not a panic stop and you were not pressing hard enough on the brake pedal.
Also keep in mind that the VW Scirocco is about 550 kg lighter than the GLK
The GLK 300 is my first luxury SUV( I have a Honda CRV), and it is a Mercedes,so my high expectation kinda biased the judgement--the unmatch set of super light steering wheel and super heavy brake pedal and the mediocre acceleration. Honestly the GLK disappoints me.
I am thinking trading the GLK with a VW R36. Maybe it is not GLK,it is the philosophy of Benz tha I don't get it.
