Windshield washer fluid light
I told them at the time that I was using Rain-X and they told me that they had to drain it and they refilled it with their brand. I never had the problem again. My question always was, how does a sensor that is supposed to indicate the lack of fluid measure the temperature of the fluid. I was always able to spray the windshield with fluid even when the indicator came on. They did not charge me but said that it was my fault.
I had reason to go to the parts department a couple of months ago and when I asked them about the fluid I should use he gave me a gallon of some blue stuff and said "here use this, this is what we put in all the cars." It was some no name blue liquid. He didn't charge me for it and while I was there he gave be a small bottle of "Summer Fit". There is also supposed to be "Winter Fit". They are just additives to help clean the windshield like detergent.
Like I said never had the problem again but still can't figure it out.
I had reason to go to the parts department a couple of months ago and when I asked them about the fluid I should use he gave me a gallon of some blue stuff and said "here use this, thiss is what we put in all the cars." It was some no name blue liquid. He didn't charge me for it and while I was there he gave be a small bottle of "Summer Fit". There is also supposed to be "Winter Fit". They are just additives to help clean the windshield like detergent.
So what do they recommend people buy? You can easily go through a whole gallon bottle in a few days if there is a storm. They can't expect people to buy their crap... grr
I did as well refer to a Daimler internal info, addressing the issue, translated (in short) from Danish:
Cause: The electrical conductivity of the fluid is insufficient due to:
- Usage of distilled or "deonized" water.
- Amount of water (providing conductivity) in the solution i too small.
- The anti-freezing additive to high.
Electrical conductivity of water decreases for example 2% per 1°C (1,8°F). Assuming various washer fluid brands “behaves” accordingly, the conductivity of the fluid, with decreasing temperature, may finally “open” the fluid level sensor circuitry, thus triggering the display message.
An experiment would be (DON’T DO IT!
) adding a little salt to the reservoir to see if the message disappeared, as it would increase the electrical conductivity of the fluid, however the side effects -
We are using the MB Winterfit, for protection down to -18ºC (-.4ºF), mixed 1:1 with water. From the “The anti-freezing additive to high”, do I see why a higher concentration is not recommended – to prevent false Low Level Warning Display messages.
You COULD try adding a little (tap) water to the reservoir, thus reducing the mixture concentration i.e. increasing the conductivity, given the fluid still will provide antifreeze protection as required for your area.
I have been using the -20*F fluid so next time I'll try to put some tap water in there, and hope it doesn't freeze.
Our replacement sensor is most likely manufactured at specifications as for the original (another statement given). We haven’t seen the error message after the replacement, however have environmental temperatures only been down to the “critical point” – so far. We will see – and report
Im happily using my 1z Krystal Klarr + 1z Antifrost Washer fluids
