Tow Hitch & Wiring DIY - Big Savings
Old Dec 30, 2013 | 10:44 PM
  #76
FC_GLK's Avatar
2014 GLK 250, 2016 Volvo XC70, 2013 Jeep JK Sport
Toogrumpy: Would you mind posting a pic of your Curt install? I also have a 2014 BT and would like to take this install on myself.
Old Jan 5, 2014 | 12:57 AM
  #77
toogrumpy's Avatar
GLK250
Originally Posted by ranger2013
Anyone know if the the Curt 56200 lighting module used by the OP will fit a 2013?
I checked with Curt and the tech did not know.
Another way of asking is the 2013 GLK 350 rear lighting system the same as the 2011 model year.
Thanks,
Bob
I did go ahead and let Uhaul install my lights. I was concerned because the part number of the wiring kit said it was for the GLK350. I actually cancelled my install and told the shop why. Then the Uhaul store manager said he would check with the Uhaul tech support. They didn't want to destroy the wiring either. Uhaul tech support supposedly check with Mercedes USA, they said the light wiring on the GLK 350 is the same as on the GLK250. A least as far as the trailer lights are concerned. I really wanted to do the wiring myself, but decided in the event there was a need for a warranty, I let them do it.
Old Jan 5, 2014 | 01:22 AM
  #78
toogrumpy's Avatar
GLK250
I think the photo did load, I hope. I don't think it's great looking hitch, but it'll will work. My other car is an 09 Subaru Forester, it's hitch is 2 or 3" high off the ground than the GLK's Curt hitch.
Attached Thumbnails Tow Hitch & Wiring DIY - Big Savings-20140104_215942.jpg
Old Jan 19, 2014 | 08:50 AM
  #79
billhig1's Avatar
2001 CLK430, 2010 GLK350
Cool lessons learned
I just installed a Curt hitch on my 2010 GLK and first I want to thank everyone who posted. It is appreciated, even if sometimes the responses you get are not positive. I thought I would post some of the things I learned along the way.
1) The first thing you need to do is buy "Exhaust Hanger Pliers" I got one off Amazon made by Lisle for $18 and it saved me a ton of pain and suffering. If you can get the pliers on the pliers on the hanger, one squeeze and it's off. The rear ones are more challenging but still a lot easier than any other method.
2) Take the time to remove the exhaust tips. The instructions don't tell you to do this but it helps immensely and prevents them from getting damaged. There is a single screw and then they are press fit on. I tapped mine off from behind with a rubber mallet.
3) There are two part numbers from Curt, One fits all years(I don't have that number) and one fits just 2010-2012 (13059). Apparently MB made a minor change in 2013.
4) Holding the hitch in place while trying start the bolts to the nut plate is impossible without 4 hands. Start the nuts onto the bolts through the frame first and that will hold everything in place so you can wrestle with the nut plate on top of the bumper brace.
5) I could not find the access hole in the driver side beam for the bolt so I fished it in from the end like the passenger side. I took a grinder to the corners of the bolt plate they give you and then was able to fish it in between the bumper cover and the end of the bumper brace. If you do the passenger side first, you see what you're working with. I cut a length of fish wire off the passenger side after I put that in and fished a wire from the bolt hole out the back of the bumper brace and then hooked that onto the end of the fish wire with the bolt and plate on it. Then just pull the first wire back through.
I had plenty of room between the muffler and the hitch, over 1/2"
Good luck
Old Jan 19, 2014 | 06:06 PM
  #80
zboost300's Avatar
glk250
Good luck
pictures? did it look as ugly as the one posted above?
Old Jan 19, 2014 | 06:10 PM
  #81
FC_GLK's Avatar
have to agree, toogrumpy was kind enough to post this pic, and thanks for that... But this made me rethink installing an aftermarket hitch.
Old Jan 19, 2014 | 09:51 PM
  #82
billhig1's Avatar
That's what it looks like. Its tucked way under the bumper. Unless you lay on your stomach taking pictures its not very noticeable. It looks much less obtrusive than the Hiddenhitch.
Old Jan 20, 2014 | 11:26 PM
  #83
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
The pliers are clever but I have not utilised them in the past. My method is to support the muffler or whatever is suspended with my floor jack until the tension is off of the hanger. The hanger is then easily removed. I will be doing this in another week or so & hopefully I will not need the pliers!
Old Mar 19, 2020 | 10:26 PM
  #84
mono4lamar's Avatar
2013 GLK250
Can anyone re-up the photos for the taillight wiring? I'm working on my 2013 GLK250 and I'm getting some unusual results. I don't have a friend to stand on the brakes or a test light (multimeter set on DC) to make things easy.
A photo or pinout of the drivers side and passengers side brake light harness connectors would be wonderful!
Old Jan 29, 2026 | 10:05 PM
  #85
eg1HnS4AHskZ's Avatar
2012 GLK350 4matic
Curt Trailer install on 2012 GLK350
Decided to share my recent experience with installing a Curt hitch on my 2012 GLK350 4Matic. At the time of writing this, there are 2 versions of the 2-inch hitch for sale at eTrailer. I went with the cheaper version to try and save a few bucks but didn't really pay attention to the suggested difficulty of install rating = 9 out of 10. If you read nothing else, and unless you really like punishing yourself, go ahead and splurge for the slightly more expensive newer Drawtite version to avoid the headaches I encountered during installation with mine.
If you do not have a exhaust hanger release tool to help you remove the exhaust hangers from the rubber holders, then do yourself a favor and get the tool along with soapy water to treat the rubber mounts. Makes the job of exhaust lowering significantly easier,
Toughest part of the installation has been trying to fish the bolt and rectangular washer through the driver's side rear beam frame. Very little space to fish the rectangular washer through between the hole on the back of the frame and the rear bumper valence. Passenger side was fine by utilizing the emergency tow hook rear bumper pop out.
Was also surprised when I encountered problems with the reinforcing arm having clearance issues with the rear underside plastic guard for the emergency tire wheel well. Ended up having to remove the plastic piece in its entirety to give the tow hitch enough clearance.
Curt 2 inch hitch
Curt 2 inch hitch
Curt 2 inch hitch
Curt 2 inch hitch
Needed something to hold up the exhaust while I was removing them from their exhaust hangers.
One of the 6 exhaust hanger rubber holders to be removed in order to drop the exhaust.
Really tight clearances to try and reach some of the exhaust hanger rubber holders to lower the exhaust out of the way to install the tow hitch.
Old Jan 30, 2026 | 12:05 AM
  #86
2012 GLK350 4matic
Curt 2 inch hitch reinforcing arm
View of what the stabilizing/reinforcement arm looks like on the underside of the 2012 GLK350 4Matic. I did notice that these bushings looked worn. Anyone know what these bushings are called and whether or not they need to be replaced?
Curt 2 inch reinforcing arm in black as connected to the rear suspension cross frame.
Anyone know what these black bushings are called and whether the wear is normal?
Not sure if this is normal for the black bushings…it is a 2012 GLK350….
Old Jan 30, 2026 | 09:07 PM
  #87
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
What torque did they give you, and what size bolts are the 4 bolts that clamp around the cross member? I was not able to achieve the recommended torque (1/2-13 bolts,110 ft-lb, IIRC) without crushing the cross member...
Old Jan 31, 2026 | 07:37 AM
  #88
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
I wish my GLK was that clean and rust free underneath. 16 years of salty winter roads has taken it's toll.
Old Jan 31, 2026 | 09:10 AM
  #89
Vssman's Avatar
2010 GLK350 4matic
Keep an eye on that. I just had my rear subframe replaced, thankfully under warranty, for rusting out. The back end gets a bit squirrelly when it finally breaks apart!
Old Feb 1, 2026 | 10:46 AM
  #90
2012 GLK350 4matic
Instructions stated 110 ft-lb but I too was not comfortable with that high of a torque level given what I felt as though I might be causing damage to the cross member. I only did about 60 ft-lb for all of those bolts and will keep an eye on them.
File Type: pdf
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
