Engine Oil level
Old Jun 29, 2011 | 02:44 PM
hanli0315's Avatar
GLK350
Engine Oil level
Any of you know how to check engine oil level through instrument cluster on GLK?
I know there is dip stick, but just curious.
Old Jun 29, 2011 | 09:05 PM
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
No way thru the instrument cluster.
Old Jun 30, 2011 | 04:52 AM
allanX204's Avatar
Originally Posted by hanli0315
.....check engine oil level through instrument cluster...
...never knew we could go through the instrument cluster - isn't it closer through the glove compartment .....couldn't resist.
Old Jul 8, 2011 | 06:05 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
By the way... the owners manual is wrong for 2010. The oil capacity for the 3.5L V6 4-Matic is 7.5 US quarts, not 8.5.
Old Jul 12, 2011 | 02:40 PM
hanli0315's Avatar
GLK350
good to know, thanks a lot!
Old Jul 12, 2011 | 06:07 PM
HDRyder9's Avatar
GLK350
Isn't the 2 wheel drive 8.5 quarts and the 4 wheel drive 7.5 quarts?
Old Jul 12, 2011 | 07:10 PM
MKenM's Avatar
Just curious where does it say that?
Old Jul 12, 2011 | 07:44 PM
MBRedux's Avatar
Yes!.. you're right, but the manual for 2010 does not differentiate between the two. In fact it says "All Models".... this is wrong just like the octane sticker inside the filler door.
On page 334.
Old Jul 12, 2011 | 09:33 PM
MKenM's Avatar
I have an early 2010 and my manual on page 318 says "ALL MODELS" 8.5 US qt (8.01) which I assume is liters. That is Engine with oil filter. I have always used 8.5 qts and the dip stick reads just fine.
Old Jul 13, 2011 | 04:24 AM
allanX204's Avatar
read this, especially post # 19, 22, and 23
https://mbworld.org/forums/glk-class...ice-sheet.html .... it's a "sticky"
Old Jul 13, 2011 | 10:30 AM
MBRedux's Avatar
Well, you must not have a 4-Matic then.... ? Or something else is at play here, like not being *perfectly* level when checking the oil level.
GLK 3.5L Gas w/4-Matic Oil Capacity / filter = 7.5 US Quarts
GLK 3.5L Gas Oil Capacity / filter = 8.5 US Quarts
Old Jul 13, 2011 | 08:22 PM
MKenM's Avatar
I do have a 4-Matic and 8.5 quarts brings it up to the top marker on the dip stick. Go figure?
Old Jul 15, 2011 | 05:40 PM
MBRedux's Avatar
Check with your dealer. The 2011's owners manual is correct, 7.5 quarts US for 4-Matic GLK's. They did not change the size of the sump.
Old Jul 15, 2011 | 07:14 PM
MKenM's Avatar
BTW I have a 2010 not 11 and I don't bring it to MB for oil changes. For whatever reason 8.5 Qts. does the trick for mine.
Old Jul 15, 2011 | 09:36 PM
MBRedux's Avatar
That's what I mean, check with the dealer for an oil quantity update, not for them to do it. We change our own oil as well on our 2010 4-Matic and 8.5 US quarts with filter is way over the top on our dipstick! The 2011's have the same engine/tranny and their OM says 7.5 US quarts on 4-Matic...
Old Jul 22, 2011 | 10:52 PM
hanli0315's Avatar
GLK350
It's very interesting you mentioned that. I was bored the other day and started to check all my service records from dealer. I realized every time they charge me 9 US quarts of oil, there did they put all that?!! I know one quart is like 6,7 bucks, but it's still a rip-off!!
Another thing to notice is most recent oil change they used penzoil, I'm assuming it's still the platinum european formula which is MB 229.5 approved. They better used that, I would be pissed if not.
Old Jul 27, 2011 | 11:21 PM
Papillon1108's Avatar
Mercedes Benz GL 450, Mercedes Benz GLK 350, Mercedes Benz S 550
When I bring our vehicles for an oil change to the dealership, as far as i know they have been using Mobil 1 oil. I never bothered checking though. But, as to my knowledge, that is what they have been using.
