Backup camera Part1
Old 10-28-2011, 10:05 PM
ble2716's Avatar
Very very slow
Originally Posted by bop11
Which camera did you finaly get? Yours seems to have a better angle for looking further back. Although mine is great for parallel parking so you can really see how close you are to the guy behind, I would like to see a longer view. I could modify the mount, but at $25 it is easier just to replace it.
Bop,
The camera i got is from eBay, which is around $26US.
Those measure lines are not accurate, as you can see at 0.5M it's already at my car's bumper. At first, I wanted to adjusted the camera's angle to reflect the line's accuracy but I didn't do it mainly because I don't want to going through the whole trouble of creating a bracket.
But for 26 bucks, I am not complaining at all.
Old 12-26-2011, 09:46 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Nice work...great writeup.
Old 01-04-2012, 01:14 AM
longmanzz's Avatar
GLK 350 4Matic 2012
Does any of you have experience installing on a non-Nav GLK 350 2012?
I just got my 2012 GLK 350. It doesn't have the backup camera neither the navigation system, but it does have the standard 5' LCD. I am thinking to install a backup camera. Does anyone have recommendations on what I should buy? I was looking at the NAV TV interface which itself costs whopping 700 bucks.
And does anyone in Seattle area know a good shop to install that? The MB recommended shop asks for $1800!!!
Old 01-04-2012, 09:08 AM
Former Vendor of MBWorld
Cartronics's Avatar
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
We have a combo camera/interface kit, and can also get installation set up for you too. Give us a call directly.
Old 01-06-2012, 07:59 PM
longmanzz's Avatar
GLK 350 4Matic 2012
Old 01-06-2012, 08:08 PM
ble2716's Avatar
Very very slow
No. Not myself.
Try Cartronics, see if he can help you out.
Old 02-29-2012, 09:54 AM
  #32
rminck's Avatar
2013 GLK350
Originally Posted by ble2716
Bop,
The eBay descriptions include the following caveat:
This camera is PAL colour encoding system-only.Pleasee find out what system(NTSC,PAL or Secam) is supported by your monitor/Navi system.Please let us know if you need NTSC or Secam camera.
How do I know which one I need--PAL, NTSC or Secam? I have a 2010 GLK with small monitor and NAV. Thx.
Old 02-29-2012, 10:48 AM
  #33
Cartronics's Avatar
You need NTSC
That camera would also be HIGHLY suspect as false advertising too. It would be very difficult to actually make, and assemble a CCD camera for that price. I would suspect it is really a CMOS, as they are very common in that price. The typical layman would not know to challenge the advertising, so easy for them to get away with it. It would also be impossible for it to have a glass lens and is plastic at that price. Plastic lens 'craze' or fog rather quickly do to road grime, salts, exhaust gasses, etc.
Old 02-29-2012, 10:55 AM
  #34
rminck's Avatar
2013 GLK350
Thanks for the info. Warning understood. Appreciate quick response.
Old 03-01-2012, 08:59 AM
  #35
ble2716's Avatar
Very very slow
When I ordered mine, it came as NTSC.
They will send you other format only if you request it.
Cartronics might be right, it might be CMOS instead of CCD.
I couldn't be bother for that amount of $$, it works well for me so far.
Old 03-01-2012, 12:53 PM
  #36
rminck's Avatar
2013 GLK350
BLE27: OK. Then all should be well. I'm looking at the Sony CCD cams on eBay. They are NTSC so all should be well. And for those prices I'm not concerned about glass vs. plastic lenses.
Old 03-01-2012, 01:00 PM
  #37
Cartronics's Avatar
The reason we mention it, is most cameras have a permanent connection and you have to require most if not the whole thing when replacing... That takes a lot of time and as installer if we have to do it more than once, we loose serious money.
Old 03-01-2012, 01:06 PM
  #38
rminck's Avatar
2013 GLK350
CARTRONICS: Point well taken! Following the procedures outlined in this thread, I believe the replacement should be limited to the area from the RCA connection at the drivers rear tailight access to the camera, minimizing the pain somewhat for DIY-ers.
Old 03-01-2012, 01:58 PM
  #39
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
is the OEM camera a CCD or CMOS?
Old 06-27-2012, 12:47 PM
  #40
glkwalker's Avatar
GLK 350 2010
Sorry guys I didn't understand one thing. Wiring. How do I put wires through the cabin? I mean from the tail gate to COMMAND? Is there any special pipe or how is this intended to be done? I read the CABLES section twice but still don't understand it.
Lets say I brought the cable from camera to rear left section and connected it to 12V power source at the back. Now, how can I bring the VIDEO cable further through cabin to COMMAND? This part I don't understand.
Old 06-27-2012, 01:28 PM
  #41
ble2716's Avatar
Very very slow
When I did it I have the same concern as you do, but in fact it's quite straight forward.
Basically, you have to extend Video RCA to the command unit. You might have to buy an RCA extension ( I did), then hook it to the back of the command unit through FAKRA connector.
My biggest concern was taking out the command unit and scratch the surrounding areas at the time.
I read the instruction a few times over, including the ones from C-class forum.
Old 06-27-2012, 04:18 PM
  #42
glkwalker's Avatar
GLK 350 2010
No, FAKRA cable I already have and I took COMMAND out, so this part is clear. My questions seems a bit simpler:
How should I bring the wire from back to front? I mean I can literally put the wire between the seats, but it will not be aesthetically beautiful nor convenient at all. So the wires must be hidden somewhere, but where? And how?
Old 06-27-2012, 05:26 PM
  #43
NVGLK's Avatar
GLK350
With all of those mod will it void the factory warranty just in case you need it.
Old 06-28-2012, 12:30 AM
  #44
glkwalker's Avatar
GLK 350 2010
I don't have warranty anyway. The problem is how to bring wire from back to front invisibly -- that's the question.
Old 06-28-2012, 04:19 AM
  #45
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
See post # 4 in this thread
https://mbworld.org/forums/4833896-post4.html
Old 06-28-2012, 09:42 AM
  #46
bop11's Avatar
350 GLK, C280
a. I snaked the video cable across the dash behind the steering wheel with a coat hanger from the removable plate on the side of the dash.
b. Removed the plastic trim along the front door opening so to put the wire behind the left side material down to the botom
c. I ran the cable from the front down the under the door sill plate
Just pull the door sill straight up
d. Under the rear door sill, no need to pull this one off. Just push cable under from the inside.
e. Up the back of the rear door opening (remove the trim piece for access) and snaked it through the padding into the back where I could connect to the RCA jack from the camera
Please note I did not have to drill any holes to do any
of this job. The holes are there you just need to find them. d. I taped the RCA connectors together.
The wire is completely hidden
Old 06-28-2012, 03:44 PM
  #47
glkwalker's Avatar
GLK 350 2010
Thanks guys for the replies! That resolved the question. Now I got another question about camera wires.
I realized that I have 3 wires going out from my camera. I attached the screenshot. What are "Wire A", "Wire B" and "Wire C" for?
Old 06-28-2012, 04:48 PM
  #48
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Red = power
Black = ground
Other = video signal
No..?
Old 06-28-2012, 05:16 PM
  #49
glkwalker's Avatar
GLK 350 2010
Smile
I'll check it today which is which.
Got another question. I took COMMAND out and the Green plug is already taken by something inserted into it! What should I do?
Thanks guys for help, I feel like I am very close to the finals
Old 06-28-2012, 09:52 PM
  #50
ble2716's Avatar
Very very slow
The plug with the green connector is where the backup camera plug into.
I am not sure what you have there before.... could be a backup camera before that ??
Quick Reply: Backup camera Part1
