Backup camera Part1
#76
I haven't seen glkwalker lurking around here for a while, maybe he moves on.
Anyway, there are more than FAKRA connectors back there but the GREEN one is the one you should go after.
Since you have the command unit out, which is a big progress, check all the functions to make sure everything is working correctly.
Next, unplug the green FAKRA connector and plug-in the camera and try to see if it works. IF it does (and it should), then go back and check all the functions on the command unit again just to make sure everything is working as before you unplug the green FAKRA connector.
#78
2004.5 c230k
2015 GLK350
Hi guys, wondering if any of you have tried installing a rearview camera on the 2015 GLK350? I volunteered myself to see if I can help install one on my girlfriends. Not sure if it's all going to be the same as the older models. It does have command/nav and at a quick try at the system menu, it looked totally different than the pictures in this thread.
Any input is great!
Any input is great!
#79
Your car is pre-wired for camera. Just no camera installed. You can use a OEM camera and use the OEM cables or just unplug the green fakra and use aftermerket cables. Simple as that. NEVER have to worry about taking the conector out. Just for camera.
tazzz3.2 (04-24-2016)
#80
Any input is great!
Any input is great!
#81
VERY simple answer to this.
tks
#82
I have no clue where they hide it. Should have been in the trunk door you think. But maybe it just goes to where they have the module for this feature.
tazzz3.2 (05-01-2016)
#83
My wife is getting a used 2015 GLK350 and she has to have the backup camera. It has the non-nav radio but is prewired for the Becker Map Pilot if that makes any difference. Does the non-nav radio have the FAKRA connector in the back or do I have to get one of those $300 modules to interface with the factory screen?
#84
may be you know where is hidden this famous module for rear camera
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
i have no idea at all !!!
brgds
#85
I read on another post that the cable that is already connected to the Fakra camera connector goes to the glove box to be used for an aux camera if you want to. So you should be fine just disconnecting it and connecting to your new camera. Seems that if this is true though, you should be able to connect to the camera port inside the glove box and you would not have to remove the head unit at all.
#86
i'don't really know if my connector into the gloves box is for vdo and comes from the only fakra connected at the back of my ntg4 .
i joint the photo of this connection syst in the G.B is an option code 518 called "UCI", (universal comm. interface)
but!!!!! what is the function of this strange connector ? i don't know
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#87
Camera Brand/Link to the Camera bought
hi,
Can you please tell me which camera did you buy and from where?
Thanks to bop11, Rick Hunter & VaderSS. ![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
I've just installed the backup camera for my GLK.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Below are some of the pictures, which i took from my blackberry, which is not the greatest.
The back of my car, camera installed just above the license plate.
![](http://farm7.static.flickr.com/6229/6286438087_6ae4dc4392_b.jpg)
Picture taken from inside my garage.
![](http://farm7.static.flickr.com/6100/6286395991_48e07e6c79_z.jpg)
Picture taken in a parking lot.
![](http://farm7.static.flickr.com/6118/6286913308_bc26c9a788_z.jpg)
Picture taken at night (it was raining at the time too).
![](http://farm7.static.flickr.com/6101/6286910320_52cf1264b8_z.jpg)
Hopefully an extra eye will help!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
It was a great exercise, i know a bit more about my car.
Would I do it again???? DEFINITELY![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
#88
http://www.ebay.com/itm/161475287761?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
#90
Thanks for the advice ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#91
#92
350 GLK, C280
The camera I bought was a Sunway
Special Car Rearview Camera for Mercedes-Benz S-Class
Product model: GK-CA369
Lens Angle:170 degree
Sensor:OV7950/VC703,Color CMOS
TV system: PAL/NTSC
Resolution: 420 TV Lines
Effective Pixels:656×492 pixels/704×576 pixels
Minimum illumination:0.1 lux
IP Rating:IP68
Unique Design, With reference line functions
Don't know if it is still available. Need to modify slightly to fit next to license plate lamp hole. Mine is angled down to much, some day I will re-position it.
TV system: PAL/NTSC
IP Rating:IP68
#93
I bought the camera on eBay from a Chinese merchant ( can't remember now).
While it said "CCD lense" but I doubt it would be but for around $25 I can't really complain much.
Just search "Glk350 back up camera" on eBay and you'll see a lot of them comes up.
Look for wide angle ones, like bop11 suggested above.
Most of them comes with a plastic mounting bracket and it maybe a bit loose. Just use a little of automotive silicone to glue it in place. I used a product called "GOOP" and it works really well.
#94
#95
Back up Camera for 2012 GLK with nav. already
would anyone in the NY/NJ area be able to install my back up cam. on my 2012 GLK 350. It has navigation already, and the option to turn on back up cam on R.
so not sure if I can just by the camera and have it installed.
I like Emerald Mobile Integrations products. so I could buy the camera from there.
of course I'd be willing to pay someone with the right expertise..
thanks all..
thanks all..
#96
GL 320, 993TT, BMW 550XI
thanks all..
thanks all..
#97
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
thanks all..
thanks all..
So I have an appointment to have the OEM camera installed.. I have the Navigation from factory and have the option to put the Car in R and screen switches to camera mode with the lines and all but no image.. hopefully the GLK is pre-wired to just have the OEM camera installed.. from what the installer says.. they have done many of these.. so I will keep my fingers crossed.. will let you guys know what the end result is..
Bought the OEM camera from a seller whose GLK was totaled due to front impact.. camera has clips and everything.. mint condition..
#98
Camera Info Please
Bop11,
On the camera you installed, did you use a relay to signal with the reverse light, or because of the Command Module programming did that negate the need for that extra circut?
So it was just 12V PWR & GND and the RCA line?
Thanks,
Riesling
Thanks,
Riesling
#99
350 GLK, C280
No relay. The camera is always on with the ignition, just the software in the navigation selects that input when the vehicle is in reverse. This is set up through the setup screen for the Nav and then the Engineering menus.
Riesling (06-19-2018)
