GLK parking light led
After lot of tests, this is my definitive solution...
Original T10 w5w bulbs
Philips Vision led w5w 4000K
No bluish color, simply perfect! The same color of the original bi-xenon HID.
The 2012 version of these leds doesn't produce error on CDB.
m00nd0gy (11-25-2023)
eBay.it seller f......as 25€ (33$): the seller told me that the 2012 version of these bulbs has a different resistance. It's very simple to find these bulbs on ebay but I don't know if the previous version shows error on cdb.
Anyway, Philips suggest "for interior use" and don't promise compatibility with cdb but they function well and without ERROR on Cdb. For the license plate they seems too brighter: I used the original w5w blue bulb that I removed from front lights.
Here two useful links with photos:
http://www.clublexus.com/forums/gs-t...ng-lights.html
http://forums.justcommodores.com.au/...ml#post1948036
1) Turn housing cover anti-clockwise and pull it out.
2) If you don't have little hands... pull out SLOWLY the cables of the bulb holder
3) change the bulb: as I've told in previous post, the 2012 version of these bulbs doesn't require additional resistance on GLK
4) insert the bulb holder in the hole: this is the only step a little complicate...
5) Attach housing cover and turn it clockwise until it engages
Link http://www4.mercedes-benz.com/manual...&part=in-depth
Bye
