Memory card
Old Mar 4, 2012 | 05:08 AM
bobhammer's Avatar
GLK350, AudiTT 3.2, S-Class
Memory card
I used a PCMCIA SD card adaptor on my GLK, I have a 32gb memory card with loads of songs in it, but i do not know why, some files do not appear on the comand system, but I can see them with my computer. I have tried to restore my memory card, but the problem still persist. Anyone has experienced that before? please share your thoughts.
Old Mar 4, 2012 | 09:51 AM
MBNA109's Avatar
2015 VW GTI.S4; 2016 Audi Q3 Prestige
Which adapter are you using?
The MB oem adapter can only handle up to 2gb sd cards.
Search for the SanDisk 6-1 adapter in the forums archives to learn about its expanded capacity handling.
Old Mar 4, 2012 | 07:02 PM
bobhammer's Avatar
I am using a PCMCIA card that handles HCSD card, I used to have a 8GB and 16GB SD cards working with the adaptar perfectly!
Old Mar 5, 2012 | 10:55 AM
jfalk's Avatar
2010 GLK
I have a 32 GB card currently which works fine. Did you exceed either the 4,000 file or 255 folder limit? The 255 folder folder limit is particulalry inane, since it obviously stems from only allocating one byte to the number of folders.
Old Mar 5, 2012 | 05:29 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Cool
I have read about these limitations in other areas of this forum. Do you have a smaller card that you could try? Perhaps a pair of 16GB cards might work?
Wayne
Old Mar 5, 2012 | 06:00 PM
nickEl's Avatar
2010 GLK 350
I'm using a 16gb card and it works well. One other thing, I believe it will only play/recognize .mp3 songs. Are all of your songs .mp3's?
Nick
Old Mar 6, 2012 | 02:55 AM
bobhammer's Avatar
it sure does look like I am over the folder limits, thats why some folders and files are not showing up properly!! thank guys!!
Old Mar 6, 2012 | 07:09 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
I think if you sort your music to subfolders...like by artists, then by album...it will be ok.
Old Mar 6, 2012 | 07:49 AM
jfalk's Avatar
2010 GLK
Nope. Subfolders are the problem, not the solution. Subfolders are included in the folder count. I use folders for artists, and, since I have more than 255 artists, include some single-artist tracks in a catchall Misc folder. This means I can't put the album anywhere at all, really, and have had to jerk around with filenames to get the albums sorted properly for multialbum artists. The technology is so well implemented that it's a shame they implemented the software so badly.
Old Mar 7, 2012 | 01:51 AM
bobhammer's Avatar
ye, that is the problem I am struggling with right now, probably not going to put everything into the card!
Old Mar 7, 2012 | 08:14 AM
jfalk's Avatar
2010 GLK
A suggestion: Get the (free) program mp3tag. This program will allow you to rename the files on the memory card fairly easily. What I have done is to use artists as my folders (at least up to 255 of them) and then set as the filename: first letter of album name-track number-name of track-album name. It's not ideal, but at least every artist's albums are in order. (You will need to make some variant of this for albums by an artist which have the same first letter, but that's pretty easy with mp3tag as well.)
The further advantage of a 32GB card is that you have plenty of space to be duplicative. Thus, you can cut down to, say, 240 artists and have 15 folders left for custom playlists in which you just copy songs that you've already got into ready-made playlists. Again, it's not ideal, but it works.
Finally, you can of course have multiple cards and swap them in and out of the PCMCIA reader. The only problem here is that the defaults reset every time you take the card out and put it back in. So if you have gotten used to random play across your folders that has to be reset every time you take the card out and put it back in again.
